Question about Samsung HT-Q40 System
Samsung htq40 shows fan check and then turns off
Fan check flashes on the digital screen of my Samsung Htq40 home theater system... what can i do to fix this..
djnick989
  • 1067 Answers
SOURCE: fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Posted on Jan 09, 2008
  • 56 Answers
SOURCE: Cooling fan stopped working.
http://www.samsungparts.com/search/search.asp
try to check all the accessories for your unit here
Posted on Jul 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: Fan check shows up on display.
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Posted on Feb 11, 2010
connertamago
  • 37 Answers
SOURCE: i have a samsung home
The fan has probably failed. There are screws that hold the top casing on, remove them and check to see that the fan is not covered in dust or somehow not plugged in.
Posted on Nov 16, 2010
destom
  • 126 Answers
SOURCE: Samsung Theater System keeps flashing 'fan chk'
When it tells you to check the fan it mans the device is overheating.
you can try buying a air spray and spraying it into the device/use a vacuum cleaner on the fan ports in case there is dust blocking the system
Posted on Mar 07, 2011
When my Samsung ht-z320 flashes the word Fanchk what does that mean
does it have a cooling fan? That says to me 'Fan Check', or 'check fan'.
Aug 20, 2015 | Samsung Audio Players & Recorders
Samsung home theatre ht tz315 shows
Clean the rear panel fan. It is probably dirty.
Aug 16, 2013 | Samsung Audio Players & Recorders
Samsung Theater System keeps flashing 'fan chk' when I turn it on and then shuts down two minutes later. The Fan is spinning. Does the fan need to be replaced, or is somthing else wrong with the unit.
Mar 07, 2011 | Samsung Theater System
I HAVE A HOME THEATER SAMSUNG AND APPEARS FANCHK ON IT
the cooling fan has ceased. Blow it out with canned air or replace the fan.
Check the voltage going to the fan, and oil the bearing under the sticker.
Mar 05, 2011 | Samsung HT-Z310T Theater System
I need to replace the cooling fan, but I cannot find the right size. where can I find a replacement fan?
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Audio-equipment-Parts/AH31-00056B/0057/528/Model-HTQ40/1482/0311700?keySuffixId=NA&productTypeId=x&searchModelNumber=HTQ40&subCompDesc=Cabinet%20parts&brandDesc=SAMSUNG&modelDesc=HOME-THEATER-SYSTEM&blt=11
hope this helps.
Dec 04, 2010 | Samsung HT-Q40 System
When I turn on the unit I get a symbol that is a circle with a diagonal line through it and then the unit turns off. Any ideas? (Samsung HT XQ100 Home Cinema)
Your fan is bad.
The system is intelligent. It knows it will overheat without a fan. It also knows there is a problem with the fan, so it throws its self into self-protect mode to keep from overheating.
Have a tech check your fan.
;o)
Nov 17, 2010 | Samsung HT-XQ100 Theater System
Fan check shows up on display.This is a Samsung HT-WX70 home DVD theater system. About a minute after I turn it on, "fan check" shows up on the display. What do I need to do?
Feb 11, 2010 | Samsung HT-WX70 Theater System
Samsung ht-q80 won't open tray
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 24, 2009 | Samsung HT-Q80 System
Samsung Surround Sound - DVD Player making noise as if the cooling fan is catching on something
Samsung HT-TZ312 Theater System keeps flashing 'fan check' when i turn on and shuts down after two minutes.
Please Help
Apr 29, 2009 | Samsung HT-TZ312 Theater System
My samsung home cinema system - HT-X250; Trips off every couple of minutes with "Fan Check" higlighted on the display
Had this same issue with my Samsung HT-X50, it seems these systems have cheap fans. Mine was under warranty but when I contacted samsung they wanted me to pay to ship it to them. **** that, it would of cost me 70 to ship.
What I did was open the unit take the fan and go to a computer store asking for a similar one, I got all this done for about 10 bucks. **** that samsung warranty
Apr 09, 2009 | Samsung HT-X250T Theater System
Samsung HT-Q40 System Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
