Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
My microwave won't heat anything
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Microwave won't heat
Sounds like the magnetron has failed. :(
May 18, 2012 | GE Microwave Ovens
My whirpool microwave model wmh2175xvb1 Won't Heat
The problem is caused by the magnetron,"heart of the microwave oven" or the inverter board, if 7 years or less.
Apr 16, 2012 | Microwave Ovens
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
AMANA MICROWAVE RFS-12SW2 from subway. I have 3 broken microwaves. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat. two of them doesn't...
AMANA MICROWAVE RFS-12SW2 from subway. I have broken microwave. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat.. any help and manuals? thank you
Jul 24, 2011 | Microwave Ovens
Microwave still lights up and timer still works but it won't heat anything up
The magnetron is the most likely cause, "heats food" this part is the heart of the microwave and expensive. The other two parts to consider is the high voltage capacitor and diode, but repairs will run high depending on the nature of the problem.
Jul 09, 2011 | Emerson Microwave Ovens
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
49 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
