Question about Opticon LGP Series (lgp1125ru1s-000) Handheld
LGP1 Laptop Battery problem?
Hi, For no apparent reason my laptop no longer switches to BATTERY power if you unplug it from a power socket in the wall. I have checked the battery properties and it says that the battery is holding 73% charge but it has been at this percentage for the last 2 weeks. The green light next to battery icon on the keyboard is also no longer lighting up. Just wondering if I need to replace my battery as it may simply have 'conked out' or whether there is something wrong with the settings or the computer itself. Any help would be greatly appreciated! Cheers and thanks!
  • 432 Answers
You need to replace the battery. Battery is shot.
Posted on Jun 28, 2007
2 Suggested Answers
SOURCE:
  • 48 Answers
SOURCE: LGP 1 Laptop Battery Problem?
More than likely it is the battery. All Notebook batteries have internal circuitry that monitors the battery condition. There is a caveat though. It could very well be the chaging circuit in the notebook. The only way to be sure is by going to a qualified notebook repair center. It is certainly Not settings on the computer. Your best bet is Replace the battery and if that still fails just make sure you purchase it from a source that will accept it back and return your money if the new battery does not do the trick.
Posted on Jun 29, 2007
How do i clear the bios password
turn off your unit,,then remove CMOS battery...the after 5sec put it back..
Mar 19, 2011 | Computers & Internet
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
I cannot find where to swithc from battery to powercord on my notebook
You dont have to manually switch from battery to power cord. When ever you plug in your power cord it charges your laptop batter as well as powers your laptop automatically. Once the battery is fully charged, it powers only your laptop then. And when you unplug it, the laptop drives power from battery.
To see the location of the power socket in your laptop, refer the manual.
Please come back and rate my solution if it turns to be helpful for you or also if you need more clarification. Thnx
Apr 03, 2010 | Panasonic Toughbook CF-51 Notebook
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Shuts down for no reason
With the battery removed any interruption of the AC power will cause the laptop to cut off. The power adaptor may be faulty or intermittent or more likely the socket on the laptop motherboard may have a dry jointed connection. These problems would not be apparent with a charged battery fitted.
Otherwise [especially with P4 type processors] overheating could cause cutting out - clean any fans and make sure vents for air intake are not blocked [by bedding etc].
Mar 15, 2008 | Acer Aspire 3000 Notebook
Laptop doesn't switch on
U remove backside battery and connect power connection.Switch on ur laptop power button and check it.whether it is battery problem or ur laptop problem.
Thanks
Feb 29, 2008 | Computers & Internet
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Jun 28, 2007 | Opticon LGP Series (lgp1125ru1s-000)...
Open Questions:
See all Opticon LGP Series (lgp1125ru1s-000) Handheld Questions
Opticon LGP Series (lgp1125ru1s-000) Handheld Logo
196 people viewed this question
Top Opticon Computers & Internet Experts
Ekse
Alun Cox
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
