Pictures of older DELL harddrive so I can see what I own
  • 7,627 Answers
It would be helpful if we knew what the Dell model is? A HDD is a HDD is a HDD, I think Shakespeare said that?
Posted on Jan 06, 2013
Remove hard drive from dell
Going with Dell Inspiron i1200 series of Notebook PC;
Dell Support > Inspiron i1200 and i2200 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Left-click on Harddrive in the list.
BEFORE removing Harddrive;
Remove ALL power. Remove the AC adapter (Charger) and Battery.
Why are you removing the harddrive, may I ask?
Post back in a Comment.
Regards,
joecoolvette
Apr 29, 2012 | Dell Inspiron 1200 Notebook
How do you remove a hard drive from dell m 6400
Dell Support > Precision M6400 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/wsm6400/en/sm/index.htm
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) Suggest lay a soft Static free cloth on a table. Lay the laptop upside down on the table, Battery Compartment facing you.
3) Remove the Base Assembly Cover,
http://support.dell.com/support/edocs/systems/wsm6400/en/sm/base.htm#wp1184372
This model can use Two harddrives.
A Primary harddrive, and a Secondary harddrive.
Removal and installation for both is shown in the Harddrive listing.
Regards,
joecoolvette
Apr 25, 2012 | Dell Computers & Internet
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
Hi, I have destop[ dell pentium R 4 cpu 3 GHz 1.99 GB of ram and 40 GB rom . I want to now if can change the hard disk and put another of 160 GB. tanks you carlos.
A) If you have the Restoration Disk (CD), or a full installation disk of the Windows operating system, the answer is yes.
B) If you have an image backup program, such as Norton Ghost, Acronis True Image, or DriveImage XML, for example, the answer is yes.
The Windows operating system is copied over to the new harddrive.
It would be easier, and more cost effective to just install the 160GB harddrive as a Slave drive.
I don't know if your harddrive is an IDE (PATA) unit, or a SATA unit.
Here is more information on installing either an IDE harddrive, or a SATA harddrive, as a Slave drive in a desktop computer,
1) IDE {PATA} harddrive:
http://www.youtube.com/watch?v=4inX3nC6M1E
1A) http://www.youtube.com/watch?v=OMTOgt3UiB4
2) SATA harddrive:
http://www.youtube.com/watch?v=kCgFYNLzn18&NR=1
IDE, also known as PATA is the older style of technology.
SATA is the newer style.
(Parallel ATA
Serial ATA )
The beauty of SATA is not only the faster speed, but if you connect a SATA cable (Data cable) to ANY SATA connector on the motherboard, BIOS will find the device.
BIOS (Basic Input/Output System) will find the harddrive with the operating system on it, first.
Then it will recognize that you have a second SATA harddrive also.
(BIOS looks at both SATA harddrives.
When it finds the one with the operating system on it, BIOS will disregard the other SATA harddrive)
http://www.youtube.com/watch?v=ScqDZZeFK9I
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Dell Computers & Internet
Compter will not start up , it only sits at the Dell Logo with the bar not fully loaded
Pull any USB related (Example: memory stick) and disconnect the ethernet network cable out.
Pull the power cord from the computer for 20 seconds and power up the computer.
Some older computer does not boor with USB memory inserted.
In correct setting on the CMOS may set to boot OS from network. Check cmos and make sure it's boot for your local harddrive.
Apr 24, 2010 | Dell Dimension 4500 PC Desktop
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
External Harddrive not recognized.
perhaps this new computer has usb 2.0 while the old dell was of older standards.check whether the external hdd supports usb 2.0,,if it do so,,buy a usb 2.0 cable and start using it.best of luck
Jan 16, 2009 | Western Digital Caviar SE WD5000AAJB -...
I have two dell computers. A dell Optima GX270 with an 80 Gig harddrive (that is my primary business computer) and a Dimension E310 P4 with an 80 Gig harddrive with a hidden reserve harddrive. The Optima...
To know which is which all you need to is look on the harddrive to the back where the jacks go when you remove the jacks you will see a little plastic jack on two pins you can remove the jack to make the harddrive reserve once you remove this jack the hardddrive is know longer the main one.If you any problems please let me know thank you. (rate me)
Jan 13, 2009 | Dell Dimension E310 PC Desktop
Can I swap out a laptop Hard drive
the laptop has to support older harddrives. u;re fujitsu is IDE (ATA100)! So the other laptop has to support IDE also !
Jan 08, 2009 | Dell Computers & Internet
Poweredge 2300 Configuration Help Appriciated :)
I have a older poweredge 2300 i get the following message run program setup.
Mar 26, 2008 | Dell PowerEdge 2300 Server
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
