Question about Fisher and Paykel Dishwashers
It's showing F-1 on front panel of two drawer dishwasher. The front panel on both dishwashers is giving me the F-1's.
In the manual it says to shut off power and water, which I did, and call for service. I've shut off power and water a few times and then turned them on again in the hope the computer would reset. To no avail. Is it significant that both drawers are misbehaving in exactly the same way? We have only been using the top drawer, which we had just cleaner using baking soda. I haven't checked the drain hoses. Could they be plugged?
  • Fisher and P... Master
  • 3,247 Answers
F1 in both drawers means the base of the dishwasher (under bottom drawer) has flooded. Not sure what procedure you used to clean the top drawer with baking soda. It is likely there was a leak through the lid seals due to over frothing which has caused the flood switch to trip. If the frothing was minimal then the unit should work again as soon as base dries up. Otherwise you will have to take bottom drawer off and dry the base. Make sure the mains power to dishwasher is turned off before you work inside it.
Posted on Jan 21, 2013
  • 883 Answers
SOURCE: Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
Posted on Jun 02, 2007
  • 5 Answers
SOURCE: fisher and paykel DD-603 dish drawer
Hi there, If you have had an F1 you need to dry out the product in order to reset the flood switch. This is a simple process as follows: 1. Ensure product is disconnect from wall so that it has no power. 2. Open the bottom drawer and put your hand in through the gap where the bottom of the bottom drawer comes out and feel the base of the cabinet that houses the drawers for water. 3. If there is water present dry it out as much as you can with paper towels or old rags. This machine is designed to drain all water to the front of the base of the cabinet away from the flood switch that sits at the back left corner of the cabinet base that the drawers are fitted into. 4. When you have base of the cabinet dry you need to ensure that the switch has not moisture on it in order for it to reset and allow you to start using the product. This can be done 2 ways: 1. leave bottom drawer open for 24-48 hours to allow natural air circulation to dry out the connection. or 2. position a hair dryer to blow air into the back left corner of the base of the cabinet and dry it out quicker. This still make take up to 6 hours as the flood switch had a protective cover over it to try to prevent F1's for small spills. 5. When the product had been dried out, important that you make sure it has, when you switch on the machine the F1 should be gone and ready to use. Please run each drawer seperately on a rinse cycle to confirm to yourself that it flooding was possibly caused by something blocking the sprayarm, or something stacked too high or something got stuck in the pump temporarily stopping it from draining effectively or the product suddsing too much from spilt rinse aide in one of the drawers. If each drawer runs successfully you should be in the all clear to start using it again. Please note though: if something blocks the spray arm that is directly linked to the pump your drawer will flood as a result. If you have something stuck in the pump peventing it from draining effectively ie a toothpick or piece of broken crockery this will cause your product to flood, but you will hear an louder than normal sound when the pump is running. And finally if you spill rinse aide in your drawer when filling it clean all spilt rinse aide to prevent unit from over sudsing when running. Regards KAR-Ltd
Posted on Aug 09, 2007
RescueTech
  • 145 Answers
SOURCE: blocked drainage hose in Fisher and Paykel top dishdrawer DD603
Hello there..
How do you know the hose is blocked at all? It's rare for that to happen, I work on these machines daily as I am a Factory Authorized tech. You need to be careful in your approach to this, that is an expensive machine and it can be damaged by improper service procedures.
For starters, there is a flap valve on the end of the drain hose that would prevent you from introducing any sort of pressure backwards into the machine via the drain hose. For example, if you took and tried to blow air thru the drain hose outlet end, you would force that flap closed and create pressure in the hose. Also putting caustic drain cleaning substances is very, very bad for your machine and can cause some serious damage.
I will be happy to try to assist you, but let's start at the begining, shall we? What prompted you to conclude that the drain hose is 90% blocked? The first thing you should do is take out the rack, wash arm and tha large stainless steel filter plate. Next, pull the rotor up and out of the pump base (none of these procedures require tools) and make sure the grey impeller is not "freewheeling" or has become detached from the rotor shaft. The blue wash impeller on the top and the grey drain impeller on the bottom must be "one to one" meaning they are firmly connected to the shaft of the motor and turn together.
Next, check the tube or passageway in the drawer between the sump (where that small removeable filter screen is) and the pump's sump area (where you pulled up the rotor)
If you have any blockage, it will be in that tube.
There is some glitch here where I do not get notified of response to questions, so I will check back to this post.
Posted on Dec 14, 2008
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
  • 713 Answers
SOURCE: Fisher Paykel Dishwasher drawer not draining
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
Posted on May 06, 2010
Testimonial: "I have not tried your suggestion,but will tonight...Thanks for the fast reply....let you know how it goes...Thanks "
Bosch custom panel dishwasher
Use the add image function here to attach a picture of your installation
Mar 17, 2014 | Dishwashers
Need to take the s/s front off drawer of dishwasher
For the model you have it listed under. Ther are screws on each side of the drawer panel. Remove the screws and slide the panel down and off.
Post back if you have any questions. Thanks/Mike
Dec 02, 2007 | Fisher DD603FCSS Dishwasher
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer of my 8yr old fisher paykel dishwasher got stuck opening and now cant get it back in , botom drawer works but no power to top drawer can it be fixed ?
Not sure if your dishwasher problem has been fixed yet.
The lid seal actuator motors on the top drawer are stuck due to lack of power and therefore you cannot close the drawer. Don't try to force it in as this will cause damage.
First thing to do is to restore power to the drawer. The power comes from the filter board sitting at the base of the dishwasher. You will have to disconnect power to the dishwasher and get both the drawers out. This will give you access to the power filter board.
Refer item 15 in this diagram. It is likely the board is faulty and it supplies the lid seal actuator motor power to both drawers. (separate connections).
You have to take the front cover of each drawer out to remove the drawers from the rails. But be careful not to damage the cable and hose when pulling out. Keep a chair or something next to dishwasher to hold the top drawer.
Once you fix the filter board and restore power to actuator motors, push the lid seal up by hand to make sure it does not block the lid.
Hope this fixes the problem.
Oct 24, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Need to remove front drawer panel
There are two plastic bolts on each side of the dishwasher drawer holding the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
see installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6. This is for a later model but yours should be similar.
Hope this helps. Wonder why you want to remove the front cover?
Jul 07, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Hi, I have a Fisher & paykel DD603. A really bad smell has developed which appears to come from under the top panel encasing the dishwasher. How do I remove this panel to locate the source of this...
HI- If you mean the front panel they are removed by taking out the plastic retainers that are on each side of the drawer near the front and bottom of the drawer. They are round and about 1/2" in diameter and have a raised straight portion in the middle, they sit flush with the plastic sides. Use needle nose pliers and pull hard. Once both are out grab the bottom of the front panel and pull down, the panel should "slide" off. Be sure to have the power off to the unit (unplugged) because if there is an electrical short that is casing the short all the wires will be exposed and could give you a shock if they are melted. The controller will be in the upper right hand portion of the drawer front. Smell there. I've see them short out and be black and crispy. Good luck. Getting the panel back on is difficult but be patient and don't force it.
Feb 13, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwasher D60355 built in,
open the drawer, on each side of the drawer behind the front panel on the bottom there is a plastic pin, use a pliers to pull it out, (approx 1 1/2 inces long). when they are pulled the fron panel can be pulled down and then out, bottom comes out first. unhook ground wire. now you can push the tab in on the bottm front corner of each side panel, with tabs in the drawer will pull out of the track, lift the drawer and push the tracks all the way in and set the drawer off the the left side of the dishdrawer. hope this helps.
Aug 09, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
How do i unattach the front panel of a fisher and paykel two draw dishwasher to access the switches and control circuitry
there are 2 quarter size "buttons" on either side of the drawer(s). pull theese out. htey are pins locking front panel on, after removng pins the fron panel will slide down giving you acesss to innards
May 03, 2008 | Dishwashers
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
