Question about Cooktops
One of the burners on my gas cook top doesn't spark.
All the burners but one spark and function properly
    Sergeant:
  • 475 Answers
Did you try to take it apart make sure nothing is in the connection, and then try to reconnect again.
Posted on Jan 05, 2013
Rotu
  • 175 Answers
SOURCE: gas cook top
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
Posted on Oct 31, 2006
textonor
  • 130 Answers
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
dauphine
  • 207 Answers
SOURCE: No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Posted on Apr 09, 2008
larryyb
  • 291 Answers
SOURCE: SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
Posted on Dec 11, 2008
SOURCE: creda gas cook top sparks but does not light
I have a Creda GGH102 gas cooktop that once power is supplied to it, it will not stop clicking.
Posted on Nov 01, 2009
The igniters on our Creda cook top keep sparking. Unplugging it isn't a solution. Where can we buy repair kits, or - better yet, what solutions do you have?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 02, 2011 | Cooktops
A single glass electrode isn't sparking on our GE gas cook top. The other four burners all spark fine. There is a spark underneath the cover on this single burner - just not on the electrode on...
Is this one that you use all the time? Maybe it's dirty and you could try to clean it somehow. If that doesn't work, you could find another sparking anode at a dealer and replace it. A toothbrush or other stiff bristle brush of similar type should do it. In the meantime, you can use a lighter with the gas on low to light the unit.
Hope this is of help
Joe
Aug 31, 2011 | Cooktops
I have a 1962 or 63 Wedgewood 30' gas cook top. It has polite lights. Is there any kit to change it over from polite lights to a up to date igniter system?
no there is not the burners wont have anywhere the electrodes could mount to,plus it would need to wired for a spark module and find spark switches for the valves that were never designed to fit those gas burner valves
sorry
Jul 27, 2011 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Cooktops Logo
90 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
