Question about Radio Communications
My Galaxy 94h shorts to ground when I try to hook it up, even if radio is off
May have been getting 15 volts or so from power supply when if happened
  • Ernie Jan 12, 2013
    It was a final transister in the amplifier that failed to ground
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
The reverse power protection diode has shorted open
Posted on Feb 28, 2013
Connex 3300 went to ground what can i do
There is something shorted in the power supply. See if you can get a schematic from their website. Most likely parts to check are the voltage regulators, protection diodes and capacitors. A shorted diode will go to ground too.
Nov 19, 2014 | Connex 3300 240-channels Mobile Cb Radio...
Radio and cd player do not work on my 95 bronco...should i replace it or try something to test it?
i would test it even if you go with an aftermarket radio you will have to have all your power and grounds.to test it simply pull the radio out to get the the wires.The red wire is a 12 volt ignition when the key is turned on it sends 12 volts to turn the radio on,the yellow wire is 12 volt constant it should always have power on it.,and finally the black wire is your ground the easy way to test the ground is to simply take a test light and hook it onto the positive post of your battery prob the wire and make sure it lights up.To check for power just do the opposite hook the lead on the light to the ground post on the battery.you may have to have a wire ( a jumper wire) to use to hook in between the battery and the test lead on your light.
Oct 07, 2013 | 1995 Ford Bronco
How do you make this work ???? I hooked it up I think and nothing is happening
whatever watt that amp is find a computer power suply that has same or more watts, when you get it you will notice there is a large bundle of wires that go to a 10 pin or more plastic clip. if you look at it with the clip lock facing up, you will see a green wire 4th one in from the left and black ones on both sides of it, bridge the green and the black one directly on the right of it, that is what will turn the power supply on, find your 12 volt and ground on any of the smaller clips, 12 volt is yellow 5 volt is red and ground is black, just hook your remote and power wire to the yellow and ground to ground, i recommend you hook a switch to it so you can turn it off !! and i DO NOT recommend using a power supply with less watts as you amp! nor do i recommend trying a xbox 360 power supply something WILL blow!!
Apr 19, 2013 | Audio Players & Recorders
Galaxy 94h no frequency counter
get a schematic of the radio and use a volt meter to check out the voltages coming to your counter.
Jan 05, 2013 | Radio Communications
Galaxy 94h no frequincy counter
hook up a frequency counter and adjust L14 and L15.
How to Hook up My galaxy 250 watt Linear Amplifier to My galaxy dx959
you will need a jumper cable to go from the box to the radio then the antenna plugs into the box at the antenna connection point.Now for DC power you will need at least some 12 gauge wire with a fuse connected to the pos and the neg. Then you connect it to the fuse box and a ground . I personally would not use one ,if my radio cannot out do yours then so what.If you can't hear my radio within 12 miles of me then I will talk to you when you get closer.You want to hook one up thats your option but I don't even want one.
May 27, 2012 | Galaxy Radios 959 40 Channel Am/ssb Radio
I disconnected and reconnected the cobra 29 nw ltd classic and now my voice is heard very low and slow it was working fine just before disconnection. can you help
How did you disconnect it?? Antenna wire?? Power supply?? Microphone?? May be that you have a short in your coax in back of radio. Try taking it loose and screw it back in. Try new coax. Turn up Mic gain knob or change microphone. Make sure power wires are connected RED to RED(+) and Black to Black(-). Try grounding radio to metal ; if inside house ground to metal water pipes, filing cabinet, breaker box or meter box or 8 foot rod into earth. Measure SWR it should read 1.1 to 1.5. Measure power supply with Voltmeter it should be 12 to 15 volts. Check antenna plug in back of radio is my guess or microphone itself.
May 09, 2011 | Cobra 29 LTD CB Radio
Wiring a power
get a 12 volt 3 to 10 amp power supply. radio Shack has many. Red(+) is 12 volt + hot..Black and metal is always ground(-).
Apr 11, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Was talking on cb and power supply went to beeping and will not quit. Unplugged it and plugged it back in and still does it. I have a Galaxy DX98VHP hooked up to it in a scale house. Took cb off and it...
THE BEEPS INDICATE THAT THE OVERVOLTAGE PROTECTION IS ACTIVATED,DO NOT HOOK UP ANY THING TO THAT POWER SUPPLY!!!OR THE FULL UNREGULATED VOLTAGE (20-30 VOLTS)WILL PASS FROM THE SHORTED REGULATOR TRANSISTORS TRHU YOUR GALAXY AND FRY IT.GET IT TESTED BY A PRO,USUALLY THE REPLACEMENT PARTS FOR POWER SUPPLY ARE DIRT CHEAP.
GOOD LUCK.
Sep 11, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Galaxy dx 2547
Hi Joey,
It sounds to me that the power supply you are using may be a little under powered. It's not really a bad problem as long as the voltage doesn't drop below about 10.5 - 11 volts. As for the Galaxy. I'm not real certain of the question but a Galaxy will usally use more current to make it work properly, so I would suggest a bigger ( more amps ) power supply.
Good Luck and I hope this has helped some
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
May 05, 2008 | Galaxy Radios DX-2547 40-Channels Base CB...
Radio Communications Logo
20 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
