Reset copy function - error code E000017-0001
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
SOURCE: Canon IR 3200
ok you have a hard drive error problem that is what the code refers to need to replace the hard drive, try to scout around for one out of another machine somewhere and put it in otherwise if you get a new HDD you need to reload all the machine firmware and you will need special tools for that and only canon technicians have access to that stuff,
as i am a canon tech myself
SOURCE: what error code will IR canon copier display when
Error E225 It is used to indicate a fault in the scanning lamp
