Question about Dryers
F-10 Code on Hotpoint Ultima CDT85
The code keeps coming up after a minute of turning the dryer on.  I have cleaned the vents but it still isn't fixed.  Do you know where the thermostat is located?
  • 3,463 Answers
Error code F10 indicates a prob with the heater element and or thermostats.
These are located behind the removable panel at rear of dryer.
If you cannot see the stats, then undo 2 screws that secure element to rear panel, and you will see the stats.
This only applys if the element is fastened to rear panel, other wise you will see them fastened to the rear of the dryer.
Please remember, this error code is only an indication of the problem and not a solution, as other factors could be involved.
Please leave a rating for my comments, or I will not know if you solved your prob.
Thanks.
Posted on Jan 20, 2009
  • Barry Coates
    Barry Coates Jan 20, 2009
    Make sure the filters are thoroughly cleaned, wash the lower front left one under running water to remove all traces of lint.
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
Does not work
Error code F10 indicates a faulty thermostat, or the common of the element is open circuit.
You need test the stats for continuity, also the element as well.
It is more likely to be the stats, you must, replace both and not just the one.
Check vents , clean filters
Remove the lower left filter, and wash it through with running water to thoroughly clean it.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code F 13
f-13 is heating element or thermostat.
remove plastic panel at bottom back, look for black marks in line with the heating element at bottom middle of drum.
part number: 1604486 may fix your problem
Mar 24, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Dryers Logo
358 people viewed this question
Top Dryers Experts
