MANUEL for older Dell hard drive Intel xeon 1.5ghz
Troubleshhoot the indicator light on the front that changes from "normal" green to amber and stops sending signal input to my monitor
  • 7,627 Answers
You didn't provide the DELL MODEL?
Posted on Jan 06, 2013
ashish13
  • 75 Answers
SOURCE: My Dell 9100 desktop won't start.
Hey mate... Now there could be a number of things wrong with your PC.. First thing is that on the back of the main tower there are 4 Lights that glow if the system is ok but in case of issues they glow in different patterns according to the potential problem... look out for those lights n refer em to this chart
http://support.dell.com/support/edocs/systems/dim9100/en/SM/adtshoot.htm#wp1054146
Also in case of potential component failtures the system gives out beep codes in patterns (maybe the sounds u hear at startup)... Do a quick check
Now regardless we can perform a basic troubleshooting...now you seem to be tech savy enough so do one thing... remove all the chords from the system... then hold dowm the power button to discharge the flea power... now remove all the components one by one n reseat them immediately... this will reset the connections n then try n restart again... if the problem persists then post the 4 led code here n we'll go from there mate :-)
Posted on Feb 11, 2009
gymowner
  • 679 Answers
SOURCE: amber light flashing on my dell 5100, green light on motherboard
The green light just means it is plugged in and getting power.Try pulling the plug, the green light will go out. If you can remove the battery out of the motherboard, "it looks like a quarter", leaveit out for a couple minutes and out it in 'The same way it was" make sure you "look" at it before removing it, it has a little release thatenables it to lock in, or pop out. plug it in and give it a start. It may just be the settings got corrupted, that little battery saves the start settings, once it starts, we can go into the bios if any settings need changing, I'll keep an eye on this post, good luck
Posted on Mar 16, 2009
SOURCE: There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Posted on May 14, 2009
  • 3940 Answers
SOURCE: can't access hard drive getting IDE master hard drive SMS mess
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
Posted on May 28, 2009
SOURCE: no signal to monitor. all cords are tight, and plugged in. no beeps when computer starts up. Can't test anything nothing shows on screen. Tried it on another computer, worked fine. amber light below g
Check the connection which links the CPU and the monitor. Also check the power cable of th3e monitor
Thanks
Nilesh
Posted on Jun 03, 2009
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
I have problem with my Dell PowerEdge 1430 xeon. the device can't start up. every time I push the power button on, I always become to 'standby' status, with LED indocator 1 & 3 ON and the...
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Remove all PCI cards and see if you see if it powers on. Check USB ports too.
Jun 22, 2011 | Dell PowerEdge SC 1430 (bscwfk1) Dual Core...
What does it mean when a,b,c, and d turn green on the back of a dell dimension 2400. the power light on the front of the case is green but th other one is amber
the information is here
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
the ABCD leds indicate the progress of the power on self test (POST) GGGG LEDs indicate POST has passed and the operation has been passed from the BIOS to WIndows
Green power led on front indicate normal operation. the other LED is likely the HDD activity LED
Jan 21, 2011 | Dell Dimension 2400 PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Dell XPS 200
Is the amber light blinking? Indicates PS not operating within specs. You can look at replacing the PS (~$79-99). GL
Aug 09, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
