Question about Panasonic Lumix DMC-LZ3 Digital Camera
Automatically turns off...
Greetings! When I turn on my camera, the lens gets in position to focus then zooms in and out, once or twice, then on the LCD screen it says to turn off, then turn on. I've taken the batteries out for awhile then put them back in there and still same problem. Please Help!
  • 73 Answers
Possible lens failure ( or - damaged ) ; up to 50 % of replacement cost is reasonable repair ( if more , trading up is advised ) ;
Posted on Aug 14, 2007
SOURCE:
Why does the focusing ring on the efs 55-250mm not retract all the way when you turn the camera off
I doesn't return to it's closed position when the camera is turned off. You have to do it manually . Turn the zoom ring to the 55 position then turn the front focus ring fully to the left.
Apr 27, 2014 | Canon Ef-s 55-250mm F/4.0-5.6 Is Telephoto...
When the camera is turned on and the 16-105 DT 3.5-5.6 zoom is attached there is a repeated clicking sound that continues until the camera is turned off. A sony camera salesman indicated it was the lens. ...
I had the same problem with my SAL-16105. It turned out that inside the lens the FOCUS DIFFERENTIAL RING (Artnr.: 321020202) was broken. The camera tries to move the focus from one end to the other when it is turned on (probably to check the functionality), but as the ring is broken, focus will never reach its end-point. Thus the camera continues to try to turn the mechanics futher until either the gear on the lens ring or one of the gears inside the lens will jump, making the clicking sounds. Another reason might be that one of the brushes ("focus brush") inside the lens that are used to signal the position of the focus to the camera electronics is damaged. (This might even lead to the mechanical destruction of the focus differential ring I think). I was able to repair my ring, but as I had to glue it, after a few months it failed again. I'm waiting for a replacement ring now.
May 15, 2011 | Sony 16-105mm f/3.5-5.6 Zoom Lens for ...
When i turn on my camera to take a pic it is blurry but if i zoom the lens all the way close to the object it takes a good pic.
Your auto-focus is not working. Inside the camera is a motor that adjusts the lens to focus on an object automatically. It is currently stuck to "close" or near focus. However, it doesn't go far focus. Check the focus functions of you camera - try to use manual focus.
Dec 01, 2010 | General Electric A735 Digital Camera
Les Error, cannot get in focus when in auto focus. I when itry and use the zoom I get a lens error and retry power on
the lens unit was not extend properly and cause of turning off once you turing on and zoom out.If you can open the camera and get the lens unit. Try to open the lens unit and clean it and try to rotate to the maximun position but dont put too much force. if you cannot do that bring it to service center
thank you
Jun 17, 2010 | Casio Exilim EX-S500 Digital Camera
I have a Nikon D40, which I recently dropped. :( Camera seemed okay, but then I noticed later that the 18-55 lens was being less than cooperative. It now is stuck on 55 adn will not zoom out. It still...
It sound like the lens zoom has broken.
If other lens is ok and this lens still focuses automatically the conection is working.
Sorry to bring the bad news but it may cost less to get a new lens than to get it fixed.
Someone else might have an idea how to fix the zoom, good luck.
Jul 05, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens keeps getting stuck/needs a good tug to zoom past 25 HELP!
Hi Rachael_amor, If the lens will not zoom on the camera will it off the camera? If not then it has some grit, dirt, and the like in the lens. You could attempt to vacuum around the zoom however, I suspect it will need to go in to Nikon. That lens is not well weather sealed, it is a inexpensive consumer lens.
Jun 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Camera wont focus or stay on
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
May 25, 2009 | Olympus FE-340 Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Aug 16, 2007 | Olympus FE-230 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Panasonic Lumix DMC-LZ3 Digital Camera Logo
42 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
