Question about Vacuums
Cord winder stuck - Vacuums
  • Vacuums Master
  • 18,424 Answers
Cord winder stuck ???????????
Posted on Jan 05, 2013
  • donald Jan 05, 2013
    We ere able to take the wheels off which hid 4 screws and were able to get at the cord winder. We were able to solve the problem. Thanks
  • Les Dickinson
    Les Dickinson Jan 05, 2013
    good glad to hear that
Electrolux vacuum ergospace stop working how to fix
I am not too familiar with this particular model but I would think the cord winder may be shorting out. I think you can take it apart by turning it on its side, pull the side strips off. It is a bit tricky but if you access the winder check the electrical conitinuity from the winder to the plug in cord. You are probably better to take it in but if you cant please be careful to not get a shock..
Jan 16, 2014 | Electrolux EL4100A Ergospace Cannister...
The cord will not rewind
These get stuck all the time...I own 2 of these , and I have done this many times...Get a can of WD40 or some type of spray lubricant with the little straw in the nozzle. Try pulling and pushing the cord back inside(don't pull it too hard) while you are spraying the lubricant directly inside where the cord comes out. push the cord back in as if you were going to force all of it back inside the cord winder. You may even have to bump the back of the machine where the cord winder is located. But it will wind back up.If you are worried about getting the lubricant on something that it doesn't need to be on , then take the Vac apart and spray it directly on the the coils of the cord winder..A lot of times, that's all they do in the repair shop when they tell you they replaced the cord winder....
Jun 15, 2011 | Electrolux Epic 6500 Vacuum
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Vacuum not running; do I have to replace the cord winder or just cord?
Typically, the cord and winder are supplied as a unit.  It is possible to fit new cord to an existing winder, but the amount of labour involved will make the job more expensive than simply exchanging the complete unit.  Even if you're going to do the job yourself, it's simply not worth planning to just fit new cable (unless you are a masochist with unlimited time and patience).  Pay that bit extra for a complete unit - you'll be glad you did (or you'll be sorry if you don't!).
May 27, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Won't start
It is most likely your cord winder. They are a little tricky to fix yourself. A repair shop will probably charge about $50. To fix it. The contacts where the cord winder plugs into the motor need to be cleaned and adjusted. Just don't let your repairman tell you that you need a new cord winder.
Jan 22, 2009 | Vacuums
Hey guys ! I have (or my wife has) A KENMORE whispertone 116. When my wife is cleaning with it it will suddenly stops.She then wiggles/pulls on the cord and it starts again and the stops.I pulled the cord...
It definitely sounds like the cord winder is the problem. I can tell you how to take the machine apart, but it's just about impossible to rebuild that winder. When you take the winder apart the spring blows apart, and it's very dangerous. I won't be doing that again. lol Another option is to replace the winder and that is just not cost effective, and it will go bad again.
You could just take out the winder and wire a regular cord in it's place if you want to save the vacuum. You can tie the new cord in couple knots to keep it from pulling out of the unit.
As for taking the machine apart, you probably found the two screws under the hood. Sometimes they hide others under the hepa filter, but the really hard ones to find are under the cord retract button. You have to pop that off to access them.
Hope this helped. Good Luck
Nov 30, 2008 | Vacuums
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
How to access and replace cord winder on Electrolux Guardian vacuum cleaner
Aug 02, 2008 | Electrolux Vacuums
Cord winder not working
Most times you will have to replace the cord rewind. Sometimes just the cord, but usually there is a problem with thr reel contacts. But now that the spring has unwound, you will have to replace it. You will need model number rather then Red Star.
Aug 07, 2007 | Miele Red Star Bagged Canister Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
