Question about Jenn-Air JMV9169BAS Convection Microwave Oven
Jenn Aire display bulb replacement - Jenn-Air JMV9169BAS Convection Microwave Oven
  • Luis Jan 05, 2013
    Hoe do you replace the display bulb, first went dim on top half and now cant see time, menu, etc  on display?
Hello, i'm looking to replace my light bulb in my jenn-air microwave oven modeljmc8130dds. any help would be greatly appreciated.
The lamp is inside the oven so it is necessary to remove the cabinet but be aware that dangerous voltages are exposed even with power disconnected.
Oct 22, 2016 | Jenn-Air Microwave Ovens
Tip
How do I replace light bulb on my Jenn-Air microwave?
Hi.
You will need to partly disassemble the oven by removing the outer cover held by screws (the cover part 2 on the first diagram). once there you will see the bulb hand side, located on the right (the bulb is part 6 in second diagram).
Before disassemblying the appliance disconnect power, by tripping circuit breaker or unplugging the power cord.
Here the replacement part for the model JMC9158AAS, listed in title: PS391758 .
Diagrams below are also for Jenn-Air JMC9158AAS.
If you have a different model, use the links listed here: Where do I find parts and diagrams for my appliance?
Here the diagrams. Click on the pictures to enlarge.
Diagram 1:
Diagram 2:
Unless you are a technician or a trained DIYer, better ringing the number listed on the owners manual to call service support. A badly assembled microwave will be dangerous for your health. The capacitor inside the microwave can also release dangerous discharge, take care and observe safety prescriptions while disassembling.
Regards.
on Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
Jenn Aire microwave oven combo, microwave has gone out. Will cost almost as much to have repairman check it out as it would to replace with a smaller microwave. We have not been able to find a comprable...
The fan can be the fan itself, the sensor or the controller. If you can find the right repair shop it would be worth fixing. The problem is finding that shop. Generally as you have found out it is cheaper just to replace.
Best advice I can give is just to call as many repair shops as you can and get a estimate. I know that the obvious thing but really unless you get in touch with "the right shop" they will charge too much to make it worth fixing. Most shops do the board replace routine. They will narrow it down to a board instead of replacing a 50 cent part. Thats really the problem.
Jan 24, 2011 | Jenn-Air JMC7000 Microwave Oven
HOw do i replace the inside bulb?
Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
Here again my instructions: How do I replace light bulb.
Regards.
Jenn-Aire over-the-oven microwave is giving off a smell.
do not use, un safe. cheaper to buy a new one than repair.plz rate-bozcro
Sep 13, 2009 | Amana Radarange Microwave Oven
My father's old Jenn-Aire microwave, Model # M170, has a rusted bottom and we need to replace it. Is there a model that is of the same dimensions so that we can replace the unit inside the cabinet above...
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
Aug 19, 2009 | Jenn-Air Microwave Ovens
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMV9169BAS Convection Microwave Oven Logo
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
