Question about Saws
Brico bs360 bandsaw parts
Where can i get 6" x 1/2" bandsaw tire
4 Suggested Answers
  • 4088 Answers
SOURCE: Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Posted on Jun 25, 2010
  • 32 Answers
SOURCE: bandsaw tire part #41815, where to buy?
A bandsaw tire is usalley defined by the size of the saw. A example is a 12" x 80" bandsaw means that the wheel (tire) is 12" and the blade is 80" . If you are unsure just measure the wheel size.
Then go online and type in (example) 12" bandsaw tires.
You will soon see that there are a few different choices in material , the stock ones from sears are cheap but will do the job. Then there are the poly orange ones that cost more but don't slip like the stock ones.
Also type in bandsaw tires on YouTube this may help because changing them can be a pain.
Hope this helped, I asked the same questions when I got my first Saw years ago and am glad to pass it on. If this helped I would apperciate a comment.
Thanks,
Shop Dog
Posted on Mar 14, 2011
SOURCE: I have been given an
It takes a 70 inch blade. Don't go any wider than 3/8 inch, a 1/4 in blade works well. Get as thin a blade as possible. The 6" wheels can be ******* blades. I had new tires made for mine but have lost the name and address of the source so now I am on a search for those!
You will probably have to get the blades custom made. I get mine made at Island Saw in Victoria BC Canada. Not too expensive.
Posted on Apr 04, 2012
Replace tire
I suggest you to check the manual of the saw. One of the easiest technique I applied on installing a tire on my bandsaw
is I lay the band wheels on a wooden table or any wooden surface. Outside the wheel, I buried 6 nails around it , like a
half inch away from the wheel. Then, I strecth over the urethane tires outside the nails then afterwards I pulled the nails
one by one. When you re-install the wheel, make sure the wheels are in balance. To check this , you need to spin the
wheel freely by hand and observe any high and low points for the new tires. Also , before removing the wheels, I advise
to mark the front site of the upper/lower wheels. This ensures the wheels will be placed with the correct side facing out.
Jul 18, 2013 | Shop Fox W1770 Vertical 21" Bandsaw 5 Hp
Need help identifying my bandsaw
I made a research on google and I found Brico BS360 band saw . However, I am not pretty sure about this since there is no any other information came out. Photo of the band saw would really help. Just try posting this to different forum site .
Apr 16, 2013 | Saws
I have been given an older bench top bandsaw make is Brico model BS 360 wouls like to know where I can get a copy of the manual for this and the blade length it requires. Thanks for the help
Apr 04, 2011 | Saws
Bandsaw tire part #41815, where to buy?
Thanks,
Shop Dog
Feb 17, 2011 | Craftsman Saws
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Can anyone tell me where to get the rubber tires for a 143 Powermatic Bandsaw? Thanka,,,,,, Gary
Bandsaw tires are sized according to the wheel diameter, so for an older machine like yours you'll need to check that first.
Then you'll have many options available, simply by googling bandsaw tires.
To get them on, heat in warm water before stretching.
Here's one link to get you started: Carter
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 05, 2009 | Saws
Saws Logo
210 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
