Question about Refrigerators
Leaking water from amana abb2221wew refrigerator
  • 8 Answers
SOURCE: water leaking from bottom of side by side refrigerator
The is a fairly easy way if you have a strong stomach.
On the back of the refrigerator, you will see a plastic drain line running to a pan underneath the box. This is the drain line for the evaporator condensate water. It is stopped up in the refrigerator section of the box.
Here is the tough part...Pull the hose out of the back until you can wipe it off with a clean towel and blow hard through the hose with your mouth.
By the way ...take your food out of the fridge...you will blow some pretty disgusting stuff out of the drain and into your desert if you don't. This will cure your leak.
Pssst...you can used compressed air if you are a wuss! lol
Good luck
Posted on Jun 10, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
louislevel_2
  • 374 Answers
SOURCE: what is the white part that holds water tubing on
hi,
tubing at the back refrigerator is the condenser, function of this is heat rejection that absorb from your evaporator inside your refrigerator,the white part of holding tube condenser is tube holder mounted by screw to hold condnser tubing has no relate inr efrigetration cycle.the screw use on tube holder was directly pin at the back side of eveporator where cooling effect emerge some ice melted or defrosted form water pass through on screw tube holder,you can fix loosen screw have some sealant pathced to hole where srcew located after a minute of drying time screw it again so that water leak may not come out to that tube holder through your condenser,
well,if that leak does not harm or not make any trouble passing through your condenser its still good condenser need to be cooled so that refrigerant inside tube can flow on liguid state effeciently.on large refrigeration such as ice plant
condenser was designed to have a water shower on tube called evaporative system.it make coole the condenser tube.
this ideas can give you clear explanation why water leaking on tube condenser.have anice day rate me,thanks a lot
Posted on May 04, 2009
localwonder
  • 6784 Answers
SOURCE: Our Amana refrigerator is leaking
HI. This may be a clogged drain pan. The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Posted on Nov 11, 2009
  • 1218 Answers
SOURCE: Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Posted on Dec 21, 2009
Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
Charlie
Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Leaking water
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
My Amana ABB2257CS bottom freezer leaked water
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com good luck
Jun 29, 2009 | Amana ABB1927DE Bottom Freezer...
Moisture on back black panel near the middle of the back of refrigerator
If this is equipped with an icemaker, check the water line for leaking also the ice maker water valve for leaking.
If you have a external condensate drain line on the rear,is it cracked and leaking?
May 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Jan 11, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
