Question about Kenwood KSC-WA100 Car Subwoofer
How do i hook up my ksc-wa100to my stock stereo
Can i hook it up through the speakers
If you are looking to just run the power solely through other speakers this will prolly not work you will still need to have power going to the amplifier.
Posted on Mar 23, 2014
How do I hook up my subwoofer and amp to my ford f150?
to hook up the amp. drill a hole in the firewall, run an 8 or greater gauge cable (greater, depending on the wattage of the subwoofer amplifier) from the battery positive lead, thru the firewall, to the amp power +, and be sure to place an in line fuse within the engine compartment, within a foot of the battery. hook the speaker up, and then run the amplifier negative lead to a bare metal part of the cars chasss, and, finally, hook the amplifier remote power lead to the acc circuit of the interior fusebox (i usually just take the acc fuse out, stick the wire in the acc fuse receptacle, then re-insert the fuse to complete the circuit).
to run the radio signal to the amp, you can use a speaker to line level converter (if stock stereo). just splice them into the stock stereo speaker leads
Apr 15, 2016 | Car Audio & Video
Speaker wire
Sorry to hear that. you may have blown out the internal amp channels in the stock radio.
Jun 02, 2013 | Buick Cars & Trucks
2001 gmc sierra rear pillar speaker setup. So I hooked up rear 4x6 speakers in the stock location. From the factory it didnt have rear speakers and when I hooked these up to the factory wires l dont have...
I would guess that GM didn't hook these wires up to the factory stereo, as the factory stereo may not have the front back fade feature. They put the wires in to save you time if you decide to put another stereo in. Look under the dash, you will probably see the other end there. I'm not sure about this. Just a guess, but my tractor trailer is set up that way, and I only have 2 speakers, but wires are run to all possible speaker sites. Good luck.
Jan 10, 2013 | Cars & Trucks
My kenwood car stereo says protect
papano poh maaayos un lgi protect ang nkalagay
May 27, 2011 | Kenwood KSC-310CCS Center Channel Speaker...
How to disconnect Kenwood KSC-WD250 Powered Subwoofer from my car stereo
There should be RCA's power and ground connections. the rca's run behind the stero, the ground runs somewhere to the frame of the car and power runs to the positive post on the battery.
Jun 11, 2010 | Kenwood KSC-WD250 Car Subwoofer
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
Where I can buy the wires for kenwood powered subwoofer ksc-wa100? please help me I search and I don't find that.
Hello annieandstev,
The part number you want is E30-5462-38. It is available from: http://www.pacparts.com/. The cost is $43.66 plus shipping.
You may want to call their toll-free number and verify that the part is in stock: (800) 421-5080.
Hope this helps.
Apr 14, 2009 | Kenwood KSC-WA100 Car Subwoofer
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
Ksc-wa100
Sep 01, 2007 | Kenwood KSC-WA100 Car Subwoofer
Kenwood KSC-WA801
if you don't mind a large car battery (and battery charger) in your living room, it will work. Another option is to get a 12 VDC power supply, capable of sourcing 100 or more amps, but that would be too costly.
Jun 15, 2007 | Kenwood SW-38HT Subwoofer
Kenwood KSC-WA100 Car Subwoofer Logo
122 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
