Question about Security BYPASS Vats Passlock Passlock 2 Saturn Bypass
What color is the trigger wire between the nuetral safty switch and ignition
  • 139 Answers
You did not specify which the year and model of your Saturn but typically Saturns do not have neutral safety wires that need to be interfaced with a remote start system. Depending on the remote start system being installed will determine the wiring method needed.
Posted on Jan 08, 2013
My 1999 ford contour will not start lights come on and everything. Please help. It makes no noise or nothing
i would check the power to ur starter . it needs batt voltage on the big wire an also batt volts to the trigger wire on the solenoid.. also try moving the shifter back an forth in park while having ignition switch in the crank position. also try it in nuetral. u could have a bad prndl switch on ur transmission.. hope this helps
Jun 28, 2015 | Ford Cars & Trucks
2000 chev wont start at key
From the ignition switch there is a yellow wire that is for the starter. probe it when trying to start. If you have no voltage replace the switch. Also, I believe there is a fusible link in the wire by the starter. It will be a different color than purple. Probe on the back side of it to see if there is voltage at start up. If so, replace with the smae color link.
Apr 10, 2014 | 2000 Chevrolet Silverado 2500
When i crank up car and not put it in gear i can turn ignition off but when u put it in gear ignition will not turn off whether u drive it or not
You may want to check the park nuetral safty switch for proper alignment & ignition switch for correct operation
May 23, 2011 | 1996 Pontiac Firebird
Try to start vehicle in park, new battery,alternator,serpentinebelt,dash signals come on,nothing. Try to start in neutral, ok. Try again inpark, nothing, then neutral, nothing? Park safty switch, or...
Try holding the key in the crcnk position while you slowly move the shift lever from park to nuetral and back to park. If at any point the vehicle tries to start while you are doing this than its the nuetral safety switch. From your description it sounds like the nuetral safety is the problem.
Dec 05, 2010 | 1991 Toyota Previa
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Starting issues
ASE mechanic.
A couple of different scenerios. first could be the ignition switch not suppling voltage to the starter. You might have good battery voltage at the starter,but not the trigger voltage from the ignition. thats the small wire on the starter. OR if i cranks a couple of times and then starts it might be a crank sensor for those engines are known for that sensor problem. keep me posted
Jan 27, 2009 | 1993 Jeep Cherokee Country
My 1996 cavalier Z24 wont start
pull a wire and ground it via useing a screw driver at the end of the spark plug boot to check for spark / if their is no spark / ignition control module / there is also a crank shaft position sensor / located on the back side of the motor under the coil packs / pain to get to / also the nuetral safty switch / to check the neutral safty switch diconnect the big harnest at the neutral safty switch put a fuse tester to the yellow wire / have someone turn the key / with the tester grounded the light should come on / now we know the ignition switch has power going through it. if there is a no power at the yellow wire / bad ignition switch / does the car have a relay located at the top of the radiator core support (up by the radiator looking down drivers side)if it does not gm will install one for free / if there is / look for the purple wire coming out of the relay and Follow it down to the starter / reconnect the neutral safty swtch / touch the small S (the smallest screw) terminal on the starter soilenoid / have someone turn the key forward check the light / this will detemine if the relay is good / CAREFULL NOT to touch the big starter wire with the little one it will jump the starter / I HAVE THE SAME CAR / Hope this helps
Oct 16, 2008 | 1996 Chevrolet Cavalier
1995 Chevy Blazer Wire Color Codes
95-97 blazer or 94-97 S-10
12volts red (there will be 2)+ ignition harness
Starter purple or yellow + ignition harness
Ignition pink + ignition harness
Second Ignition white or pink/white + ignition harness
Accessory orange + ignition harness
Power Lock lt. blue + either kick panel
Power Unlock white + either kick panel
Lock Motor gray drivers kick panel
Unlock Motor tan drivers kick panel
Parking Lights+ brown switch or rear harness
Door Trigger white - keyless module
Dome Supervision use door trigger
Trunk/Hatch Pin tied in with doors
Trunk/Hatch Release black/white + switch or keyless
Tachometer white AC ECM
Brake Wire white + at brake pedal switch
Parking Brake black at the pedal
Horn Trigger black - steering column
Jun 13, 2008 | 1995 Chevrolet Blazer
Security BYPASS Vats Passlock Passlock 2 Saturn Bypass Logo
106 people viewed this question
Top Stellar Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
Terry Hair
Tom Chichester
Are you a Stellar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
