Question about IBM ThinkPad T30 2366 Notebook
Slow startup slow all together
Why does my cpu take so long at start up what an i do to speed it up.not exactly cpu there some things i an stop from running at start up or i googled thinkpad startup and read that it was norton holding me changing av a good idea what do you suggest please help.even opening programs go slow.bought laptop used
  • S_Nandha May 11, 2010
    Which operating system do you use?
  • 153 Answers
Scan your computer for corrupt registry entries and junk files using Reginout System Utilities. This will fix the computer slow startup problem for sure !
Posted on Sep 09, 2011
  • 35 Answers
The first thing I'd try to do is see what programs are running at startup. To do this Click on Start--> Run -->type "msconfig" without the quotes.
Click on the Startup Tab and view all the programs that are running at startup. As for deselecting which programs run at startup you can directly ask me which ones you can disable. For the most part all instant messengers and most program files can be disabled.
DO NOT disable any Windows/system32 files!
Posted on Jan 20, 2009
Every thing i click on on my desktop starts then
I played around with W8 on an Asus notebook with a 1GHz CPU and found that each programme will open over the top of another.You could have many trying to run and causing the CPU to overload and freeze.
Waiting for the activity to slow from startup by observing the LED activity of the hard drive usually means all startup programmes have loaded and there is less draw on the CPU resources.Trying to access other software while startup is incomplete will compound sluggishness especially if the laptop is a netbook or has a low speed CPU.
If you experience the issue again please wait a few minutes before trying to access or cancel any programme to see if will work through any bottleneck created.
Sep 03, 2014 | Computers & Internet
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
My yahoo is so slow how do i speed it up
For running slow there are many causes:
Microsoft Registry Problems = Slow Computer!
Below can help you speed up your pc:
For IE, click Tools, Internet Options delete files (offline files) clear history (set days to save to 0 if you want) click o.k., and Restart
For Firfox, press ctrl+shift+del, and click clean private data.
Manage your startup:
Open your Start menu -> Click Run -> In the command screen type "msconfig.exe" -> In the "system configuration utility", click either "service" or "startup" tab -> Uncheck all programs that your are no longer using.
1. Right click of C Disk.
2. Click properties.
3. Click tools tab.
4. Click "Defragment now".
5. Click Defragment.
You can search which process full use you cpu, and end the process.
Under steps:
1. right click on the TaskBar.
2. click the Task Manager.
3. click the processes tab.
4. double click the CPU.
5. find if the "System Idle Process" is max.
6. if not right click and click end process.
Learn "Why Is My Computer Running so Slow?" and "How to Speed it UP":
Use the tool:
May 14, 2014 | Computers & Internet
My pc speed is too slow. sometime it hag very much .please i request you to give mesome solution
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 07, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Slow to open
Is this slow when start up the computer or slow when you open an application?
If slow when start up the computer, the reason is your computer has too much start up programs and services. All these software, services is required to open as start up of the computer, that reduce speed of log on/ start up process. You can speed up by try these steps:
1. Start - Run: type: msconfig and hit enter.
2. The System Configuration Window will appear. Click on Selective Startup. Then go to Start up tab, untick the process that you think it not importance for start up such as Acrobat Reader...ect. 3. Then hit apply and restart your computer. You can disable all of start up services.
If slow when you try to open an application, then the reason is your computer busy work with some other higher piority process. If you think that you need this application open quicker, you can go to Task Manger and End the task you don't want it run or the task that took a lot of CPU resources.
Hope this will hellp
Thanks for reading.
Jul 20, 2011 | Computers & Internet
U tube videos play slow and sound plays first then visual starts jerkly to play. I have added the max extra ram
That may be your network connection or your cpu load. I'm going to say your cpu.
On a older laptop like that the cpu can run out of power when playing video's. The extra ram should have made some improvement for other things and helped a bit with the video.
First we want to do ctrl-alt delete to bring up your task manager. Look at the CPU usage number. With nothing else running it should be 0-1% maybe as high as 2% then drop to zero. Anything higher than that and you have too much running. If you click on the top of the colom where it says CPU it will sort by cpu use. You may have to scroll up or down to get to the big numbers, most should show zero. The big number should be system idle at say 95%+ followed the task manger taking up most of the rest. Usually what happens on older machines is they don;t have the extra horsepower to cope with all the new programs demands so they bog down. So what you can do to help this is to stop anything that you don't need from running. These are things like speed loaders or auto updates. For example if you run office or use adobe products you don;t need to have it load a speed loader (which doesn;t really seem to speed up anything) everytime. If you look at what is in the start-all programs-startup these are things that are loaded at startup. Removing things from here will stop them from auto starting. If you don;t know what these things are chances are you never use them. If you drag them out of the startup to the previous menu you can still manually start them.
Next make sure you don;t have any messengers running. Most seem to set themselves up to load with windows. Some like MSN are bad for loading the cpu. So under the options for those uncheck load at windows startup.
And last you may be running a antivirus program. These are also pretty hard on the cpu. Usually there is an icon near the clock. If you right click on it there is usually a menu selection that will turn off (or back on) the antivirus program . It should restart when you reboot.
You may also want to see if there are any other programs or managers such as print mamagers or other programs that want to load at boot. Either disable these from auto starting or exit from them before trying to watch.
Those are the easy things to try to speed things up. I have a old compaq I use for watching videos from time to time that is about the same as yours. These are the tricks I use to watch youtube vids. When I don;t turn them off etc I had the same symptoms.
May 05, 2010 | Panasonic Toughbook CF-27 Notebook
My core speed drop always to 999,99 then 2000 then 1999 then 2500 and 2700mhz whats the problem ?? plzz help ??
some tips to increase your system performance
If you have an old and slow computer, do following to increase your system speed:
1- Disable Scan Disk
Click Start menu > Click run. In the run dialog box type: msconfig to open System Configuration Window. Then open "system configuration programs". In the General Tap click on Register and then check "Scandisk after error by shutdown disabled" to disable ScanDisk.
2- Disable auto start programs
Open System Configuration (msconfig) . click on the "Startup" tap and in the application list , Clear the check box for a startup item to disable it on your next boot.
3- Disable Windows Startup sound
Go to Start > Settings > Control Panel and then click on " Sounds and Multimedia" icon to open it. In the Sound tab disable Windows Startup sound.
4-disabe unused programs
Go to Start > Settings > Control Panel and click on "Add/Remove Programs" and uninstall old and useless programs.
5- Delete offline e-mails
Yes, offline e-mails especially e-mails with attachments can slow down your pc. Delete these e-mails.
6- delete temporary internet files
Temporary internet files can slow down your pc. In internet explorer click on tools menu and then select Internet Options and the click on " Delete Files and Delete Cookies" buttons to delete these files.
7- Defragment your Hard Drive
Defragment your hard drive every 10 days. To defragment your Hard Drive, click on Start menu > Programs > Accessories > System tools > Disk Defragmenter.
8- update your Windows
Turn on your Windows Automatic Update to have recent updates for your Windows.
do it in your system.Thankyou
Sep 04, 2009 | AMD Athlon 64 LE-1640 Processor...
Think pad T30 - very slow to shut down
Your computer needs a clean.
Be sure that your computer is not virus or spyware infected.
Check if the fan is working, another cause could be related to a hardware issue.
Oct 09, 2008 | IBM ThinkPad T30 2366 Notebook
Desktop CPU Fan Problem
My first check would be to see if the manufactuer has a BIOS update for the ma inboard that resolves that problem.
If they don't have one available on their website I would contact their technical support because it may be a known issue that they are currently working to correct.
At least knowing you'll know that a fix is only a few months away.
If the manufacturer claims that your problem can't be verified you may have a faulty thermal control unit on the mainboard.
Let me know what you find out.
Jan 08, 2008 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
317 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
