How to connect the tv and use it as a computer monitor
Through an hdmi cord to each device
Posted on Jan 05, 2013
How to connect 4 x HPL1706 monitors to a TV or PC/Laptop?
Did you try using a "Y" adapter cable. That would allow you to connect to two devices.
Mar 25, 2015 | HP L1706 17" LCD Monitor
Can I watch TV through my model 568 monitor
You cannot watch TV on the monitor unless the computer that is connected to the monitor has a TV tuner installed in the computer.
Jul 11, 2011 | Acer Computers & Internet
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
I connected my LG 22LD350 to my hard drive, and both the sound and picture work, after I selected "RGB-PC" on the monitor. But I don't see a connection anywhere on the TV for my keyboard and...
Hi bpollen,
you will use the computer for {GUI} Graphics User Interface!
The TV is a "secondary visual device, or monitor"
The TV "cannot give instructions or commands."
"You not be able to "tranfer information from the TV.
You will use the "Computer for [Input and Output] transmissions.
The "Keyboard and Mouse" stay 'connected to the computer!"
You will "control all functions for the TV; by using the computer."
"I hope this information solved some issues?"
!"Take a moment to rate the help."
Thank you! paul7of9
Mar 18, 2011 | Computers & Internet
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
When I connect laptop to tv can only get audio no video
  • Hello capricorn54, when you connect any type of external "Monitor" or {TV} to your computer, the computer have to recognize that a "different" Display is attached! To "Display the (TV Monitor), do the following; (right click) on an empty area of the Desktop, in the next [window] select the "Personalize Icon." Choose from the "listings" Display Settings. Next, click on the Identify Monitor [button]. You need to select the (Number 2 Monitor), this will identify that other device is connected to the computer. This will acknowledge the device connected to the computer #2 Monitor [output] is a TV. Once you have completed all the steps; click on the "Apply and OK" buttons. "I hope that this information is helpful. thanks for using FixYa, paul70f9."
Feb 02, 2011 | Computers & Internet
Could you please let me know if i can use my viewsonic monitor as a tv if so what cord do i need to get
The monitor does not have a built-in TV tuner and cannot function as a TV unless your computer has a TV tuner. In this case all you need to do is connect the monitor to your computer and start the TV tuner/program in your computer.
Jan 11, 2011 | ViewSonic VX2235wm LCD Monitor
Connect the USB to 3RCA cable from computer to TV
what TV model you have? maybe it is not on the right connection / setting
The PC must have the dual monitor mode in order to work as well what PC model you have .. specifically the video card /.... ensure that the video settings are set to TV mode as well for the default monitor
Oct 06, 2009 | HP Computers & Internet
TV isn't acting as a computer monitor - doesn't recognize computer connection
you need to use the right cable that plugs into your pc serial port in tv to the video card of your computer or same looking connection as your tv one but on the back of the computer ok
Jun 23, 2009 | SVA-USA VR-20 20" Flat Panel LCD Monitor
Connecting laptop to tv
1. If your tv has a PC input, use a vga cable, from any normal computer monitor.
2. If you use those HD connectors, match them to the correct colour coded inputs on the tv.
In each case, do all the connecting with the computer POWERED OFF. Then when connected, boot the computer, and allow Windows to auto-detect the 'new monitor', as it will 'see' it.
Then you shoud right click on your desktop, choose properties, and goto 'settings'. From there you will see monitors 1 and 2. click on the new monitor and 'enable' it.
You also have the option of 'extending' windows to the second monitor, as well as making this your 'default monitor'. Experiment to see what best suits your needs,
Erik.
May 16, 2008 | Dell Precision M60 Notebook
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
