Question about Amana Dryers
How do I get access to change the dryer belt on nmy Amana Dryer? Does the top pry upward? When I try to pry upward it doesn't move. Is there another way to get access?The model # NDE 2330 AYW
Model# NDE 2330 AYW
protek480
  • 1714 Answers
SOURCE: Amana electric dryer model #LE8217W2 belt replacement
This will help:
Posted on Jul 08, 2009
  • 152 Answers
SOURCE: I HAVE A AMANA ELECTRIC DRYER , MODEL NDE7800AYW,
Start at the bottom. Remove lower panel then remove the door panel that will expose the 2 screws that secure the top.
Posted on Mar 04, 2010
Testimonial: "thank you , I was trying to pry the top off on the two outside corners like I use to do on our Whrilpool dryer"
SOURCE: Amana Electric Dryer Model NDE 7800YW squeals when
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Posted on Mar 14, 2010
Macmarkus
  • 2605 Answers
SOURCE: My dryer needs the belt
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Maytag LDE8414ACE dryer and you need to first access and then attach a new drive belt. These are awesome old dryers by the way...keep it running as long as it is worth while, you'll never get another like it...in my opinion.
I could explain to you step by step on "how to", but I think you'd be better served by checking out the link I've attached below. The dryer in the tutorial should be exactly like your machine as it pertains to changing the belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/Y312959/1246110?modelNumber=LDE8414ACE
Thank you for choosing FixYa. Let me know if I can help in any manner to you moving forward.
Please take a moment to rate the assistance you received here and a brief testimony on your experience here at FixYa today.
Regards,
Macmarkus :)
Posted on Jun 16, 2011
hunter19_46m
  • 7482 Answers
SOURCE: need to replace the belt
Hi finer5...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley, or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on Jun 29, 2011
Drum belt loose
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed.
May 29, 2012 | Whirlpool Dryers
My kitchenaid dryer will heat up but wont spin around
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
How do you fix a dryer belt for a moddle 6670269
May 14, 2012 | Kenmore Dryers
How do i open the top to a kenmore dryer
May 11, 2012 | Kenmore Dryers
Kenmire 80 series dryer drum doesn't turn
May 05, 2012 | Kenmore Dryers
Where are my dryer belts located
May 02, 2012 | Kenmore Dryers
Inglis clothes dryer heats up but drum doesn't
Apr 28, 2012 | Whirlpool Dryers
How do I access drive motor on kitchenaid dryer mod.keys700jqo
Mar 04, 2012 | KitchenAid Dryers
Dryer won't spin
Oct 22, 2011 | KitchenAid Dryers
Belt broke on Amana dryer
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Jan 29, 2009 | Amana ALE866SB Electric Dryer
Dryers Logo
35 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
