Question about Garden
I have an ameriquip eagle 42 boom lift i drop a large tree trunk on one of the outriggers and bent the top bar and it cracked the weld what are my options
Can this be repaired or do I need to replace the whole outrigger
  • angus571 Apr 02, 2013
    Do you want to sell the unit?
  • Frank krantz Jun 13, 2013
    I have an eagle 42 towable man lift and I need a shop manual to fix a problem with the drum controler on the boom turret. Does anyone have a resource for obtaining one? thanks
    New Friend:
You need an outrigger.
Posted on Apr 02, 2013
    You need an to replace the outrigger, do you want to sell the unit?
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Need replacement crankcase for Echo CS-750EVL chainsaw
There are 2 complete CS-750EVL saws on my local Craigslist.
Try here for Echo IPL:
http://www.echo-usa.com/pdf/documentation/CS750EVL_010185.pdf
If not your saw:
EchoUSA
http://www.echo-usa.com/documentation.asp
Type your model number into the search window.
Good Luck
Lou
http://seattle.craigslist.org/see/tls/1571477399.html
http://seattle.craigslist.org/tac/tls/1571683044.html
Posted on Jan 27, 2010
My stiga deck has dropped off the brackets after hitting a tree. I can get one side back on but not the other is there a trick to get deck back on as it should be ?
quite possibly there is a bent arm and you need to force it back in I have to use a 2x4 and big pry bar to lift mine into place
Jun 01, 2015 | Garden
My trunk won't pop open when I lift the trunk release lever
you can adjust the tension by moving one or both bars. on one end it should sit in one of three notches. I have moved mine by hand but you may need a screwdriver or pry bar on some cars. also depending on the car, you may want to put something to protect your rear window. As some have alot of tension and may spring out, and hit the window. Just try different positions till you get your desired effect. And a last note sometimes the bars become bent or really weak from use. And may require to be replaced. If so then they can be ordered from the dealer.
Mar 23, 2014 | 1997 Nissan 200SX
I dropped my bike onto the side so there are some major and minor scratches that can be replaced. But not only i notice the scratches but the alignment is off. When the front wheel is straight my handle...
my buddy just went throught this same problem on a 05 gsxr check the fram where the handle bars are bet the frame is bent ot twisted just a lil if not then its ya tree tops or forks
Aug 24, 2013 | 2011 Aprilia SportCity One 50 4t
How can I get my 1998 Ford Taurus trunk to stay up on its own
If it has trunk lid supports they may need to be replaced. If it uses a torsion bar under the back window it may be bent.
Jul 06, 2013 | Cars & Trucks
On my 1996 230 timberjack porter there seem to be electrical problems in the joystick. The boom still lifts when joystick is in neutral and when boom is lifted it will fall at a fast rate. When you pull...
http://www.timberparts.com/timberparts-carries-a-large-selection-of-forestry-parts
look for wiring parts here, or find the phone number/email at the top of the page for customer service
Mar 01, 2013 | Heavy Machinery
NOISY FLEX PLATE, KEEPS CRACKING AROUND MOUNT ING SCREWS (3) , WELDED UP CRACKS AND REPLACE SCREWS, IN A WEEK STARTS GETTING NOISY AGAIN WE HAVE WELDED THESES CRACKS 3 TIME NOW, HAVE REPLACED NEW FLEX...
sounds like it is incorrect flex plate
for bolts to keep coming loose i wouldsay the bolt threads in end of crank have been streched thru over tightening
you may be able to redrill and tap these
to do this you will have to pull engine
you alsocannot weld craCKS IN A FLEX PLATE
FLEX PLATES flex THEREFORE WELDING IS A WASTE OF TIME
WELDING WILL ALSO PUT FLEX PLATE OUT OF BALANCE WHICH AGIAN WILL CAUSE CRACKS AND PROBABLY WAS THE ORIGINAL PROBLEM TO START WITH
Dec 14, 2010 | 1991 Eagle Summit
Car overheated,big boom under hood,black smoke out of back,speedometer dropping,oilpressure dropping and then car died. 94 eagle talon 5 spd
The engine has seen it's final days of providing secure and unproblematic performance. Where there is smoke, there is fire. overheating is the worst thing that can happen to an internal combustion engine.
Nov 27, 2010 | 1994 Eagle Talon
I dropped my green egg, it now has a huge crack on the side and the bottom broke in three places. how can I fix this?
I hate to give you bad news but repair is near hopeless, I would try a heavy duty epoxy JB weld or JB industro weld. notch out all cracked areas then fill notch and crack with epoxy. Allow to dry fully. JB weld is safe in high temp of engine compartments. Good Luck
Sep 13, 2010 | Big Green Egg Large All-in-One Grill /...
Getting the front forks out there bent
Ok to get the front forks out, first you must take everything off the front of the bike such as fairing, headlight, windshield, nachelle, etc. Don't forget to disconnect the battery first. Then lift the bike off the ground and take the front wheel and the front fender off.
Look on the backside of the lower triple tree. There is a pinch bolt there. Loosen the bolt and spray some penetrating oil around the upper fork tube. Then take the large "nut" off the tube at the top triple tree. You may have to drive a chisel into the slot on the lower triple tree from the bottom side to spread it a bit. Then work the entire fork tube out of the steering head. Do the same with the other side.
Good Luck
Steve
Aug 09, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
