Question about Video Game Consoles & Games
I put in a dvd to watch, the ps3 console began flickerin, looked online for info, said may be the hdmi lead so i changed back to scart and still the flickerin was still happening???????
I think its the Plugs
Posted on Jan 05, 2013
flowtron2k2
  • 95 Answers
SOURCE: No picture, after changing from HDMi to usual port
try to reset the video refresh output by holding down the power button with the switch in the back on position. hold the front power for 13 secs ..you should hear two beeps one 6 secs after the other. now turn the unit back on and the composite cables (yellow/red/white) should work
Posted on Nov 13, 2008
SOURCE: PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Posted on Dec 29, 2008
SOURCE: ps3 freezes at startup screen/ green red dots/lines,
Turn off the PS3 with the switch on the back, then turn back on. wait till the light is solid red then hold your finger on the start button for abount 10 seconds until you hear it beep twice.
It will then ask you to connect a controller via the usb cable and press the PS button. Once you do this it will bring up the reset menu.
Unfortunately the only way I found that solves this is a full system restore that wipes the hard drive completely.
You do however retain and data saved online such as COD stats etc and playstation store purchases with your PSN.
Hope this helps??
Posted on Jan 02, 2009
braddy waddy
  • 5 Answers
SOURCE: Ps3 times out "invalid format" using hdmi cable
its the game in the game there is a trade mark thing and it thinks u are copying so it does any thing to stop u by doing a error382
or
its your cords and your useing a really cheap brand the does not sut your tv and it is does not sut your ps3 so it will cut out and make errors
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: Green dot's and pixelation via hdmi
its the ps3 u have to send it back to sony! the green dots will get worse and start to freeze up ur system i had the same problem last month!
Posted on Mar 25, 2009
I was using my ps 3 on my plasma tv connected by a HD lead. I then hooked it up to another tv using a scart lead and now it won't work. I hooked it back up to the plasma tv and it works fine. I need it to...
Got to settings in the PS3 Crossbar and go to display settings. The first one should say video output settings, click on it. It should say your connection type is HDMI. Select component/D Terminal and hit change. The screen should go blank. During this time plug it in to your other t.v by the scart. It should say "Can you read this screen?" hit yes and there you go. To go back to HDMI do the same.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
Tip
How to connect PS3 to surround sound
Firstly if you have a HDMI Supported TV, change the video output settigns to HDMI on the PS3
Then change audio output to scart.
Then remove the scart block from the Scart that came with the PS3 and connect the red and white into the co-insiding ports on the back of your surround sound DVD player.
Set DVD player to AUX and away you go!!!!!
Hope this helps
on Apr 10, 2010 | Televison & Video
Ps3 trouble
1. try holding the power button at the front when you turn on the console or look up how to reset ps3 on google
2. yes it is ment to blow out hot air at the back
Dec 17, 2009 | Sony Playstation 3 (PS3) Console
Crackling sound on PS3
the laser is starting to wear out. it cant reda the audio fast enuf to keep up with the visual side of the game resulting in crackling momentary hissing or cutting out of music
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
No input signal HDMI
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
Scart to HDMI
press and hold your power button for a few secs until it beeps, do it again.This resets all of your settings.You just need to set everythin right again
Aug 20, 2008 | Sony Playstation 3 (PS3) Console
New HDMI problem
my brother had this issue with his PS3, he simply went into the settings with the av cable and hooked the hdmi up at the same time and changed the settings from auto to manual.
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
PS3 hook up to sony reciever
its in the sound settings on your ps3, change to hdmi out put, this should sort it, if not you can use your scart lead for the sound, just use red and white lead straight into your sound system or sony reciever. but you will need to set it up in the sound settings in your ps3. hope this helps
Feb 11, 2008 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
