Question about Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod - Black
Plugged in but no power
System is plugged in but will not turn on
  • Anonymous Feb 01, 2009
    Have same problem Red light is on but can't use speakers or charge it
  • drguitar Feb 05, 2009
    was listening to music then speakers just died, now I can't get them it to charge or play when plugged in.
The two connecting pins have been flattened probably due to putting the power pins on and off. i carefully squeezed the pins up so they would make a better connection. remember to do this gently and they only need to be repositioned up wards slightly to make this connection. mine works a treat now charges the speakers and my ipod.
cheers deb
Posted on May 12, 2009
  • 55360j Aug 31, 2010
    I had the same problem and this has done the trick-thanks!
System will not turn on, but I can plug another device into the external ac power plug and that device turns on. What could be the problem?
The problem could be with your power adapter in which case it will be fairly easily solved. If there is another device with a similar power adapter, check that. If the power adapter is fine, then you need to call the customer service guys for your Karaoke System.
Aug 30, 2015 | Vocopro GIGSTAR-PRO-II Professional...
My JVC HX-Z1 chimes and turns itself off and I can't turn it back on unless I unplug and plug it back in. How do I fix this?
The power supply is bad. This is not something that you can replace. IT has a bad capacitor on it.
Jan 22, 2015 | JVC HX-Z1 CD Shelf System
Panasonic sa ak220 wont turn on
The problem is in the audio output ic, it is loading the unit into shutdown. The only option is have the ic in the stereo replaced.
Mar 07, 2012 | Panasonic SC-AK220 CD Shelf System
The light wont even turn on when i try to turn mine on, it hasnt been turned on in a while so i yeh , does anyone knoe what i should do ??
  1. Make sure you are using a licensed AC Adapter (the system's power cord). The name Nintendo should be molded into the actual AC Adapter unit. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly. Also ensure all accessories connected to your system are licensed as well. (Expansion Pak, Controllers, Rumble Pak and Controller Pak.)
  2. Make sure you are not using any game enhancing devices. Such devices are unlicensed and are not recommended by Nintendo, as they may not let your system function properly.
  3. Firmly plug the AC Adapter into the AC Power Supply port on the back of the Control Deck and firmly plug the AC Adapter into the wall outlet.
  4. Make sure your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
  5. Slide the Power Switch on the Control Deck to the ON position.
  6. If it still does not work, you'll need to RESET the AC Adapter. To do this, remove all the accessories (including the Game Pak and all controllers) from the deck. Unplug the power supply from the wall outlet for at least 30 seconds, then plug it back in. If your system works without the Game Pak and controllers plugged in, there may be something defective with either the Game Pak or one of the accessories. Turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time to see if you can figure out which accessory may be in need of repair.
If these steps do not resolve the symptoms you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Dec 15, 2010 | Nintendo 64 Console
I can't seem to get my nintendo 64 connected. I've tried 3 different tvs and I got it to work for a short period of time today but it was not the game I wanted to play. After I turned the game off, I...
Nintendo 64 Power Problems
Nov 27, 2010 | Nintendo 64 Console
Won't turn on
Unplug all the input wires and then plug in just the power cable and see if it stays on then one by one add the wires bac until it does it again when it does the wire you just added may have a short in it check the line for touching wires. Let Me Know If this works for ya.
Apr 06, 2009 | Audio Players & Recorders
Intertel phone system died
Look for power on the InterTel system, any kind of lights on the system is an indication you at least have power to the system. If you are plugged into a power strip and have no lights, remove the power cord from the strip and plug it directly into an AC outlet. Be sure to turn off the system before plugging it into a wall outlet, and then turn the system back on. Good Luck
Aug 03, 2008 | Inter-Tel ECX 1000 Telephone
Power problems
The P7 plug is likely a spare for additional drives. You are experiencing a no POST (Power on Self-Test) when just means the system fails to turn on. Since it is summer, it is lightning season, and a lot of systems experience failures due to lightning.
Things you can do.
1. If the system has a modem, and the phone line was connected to a telephone outlet, remove the modem card from the system, see if it will now turn on. If no different, disconnect all items plugging into the tower except power, try again, if it turns on, then power off, try attaching items one at a time till you ID the problem device.
2. If the system still turns off immediately, then the next suspect item is the power supply in the tower. Most towers now days use an ATX power supply that costs about $30 and can be bought either at a local computer shop or on-line at places like newegg.com
Jun 14, 2008 | Medion M3 Composer 5200 PC Desktop
Wont turn on
The Plugs for video and sound may be in wrong spots.
Jan 28, 2008 | Nintendo Wii Console
No power!
every thing is working the system and the subwoofer my problem is the center and surround speakers are not working
Nov 20, 2007 | Panasonic SC-HT720 System
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod - Black Logo
510 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
