Question about Refrigerators
The refrigerator gets very warm
With the doors open, the front face of the refrigerator between the lower, refrigerator section and the upper, freezer section is exposed. This front face gets quite warm to the touch. Why is this? Is there a problem?
  • 1,800 Answers
Its usually a problem with thermostat.
also make sure of door sensors.
Posted on Jan 19, 2009
I bought hisense HR6TFF222 a month ago, and then week later there's a problem occurs on the fridge part (the lower section), it's not working very well, it's warm as in room temperature while...
Ive just had the same issue as the op with the same model fridge. The warranty center said to adjust the front level feet to elivate the front of the unit open both doors , defrost for 8-12 hours at least. This seems to be a problem in the colder months of the year. Once a full defrost has occurred level the feet again , and turn your fridge back on. Problem solved
Dec 10, 2012 | Hisense Refrigerators
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
