Question about Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod - Black
Plugged in no power
System is totally dark, it is pluggd in , have tried different outlets but there is not power. It does not turn on.
  • mattyyates Feb 18, 2009
    Same as dot4606's, just no power.
  • alex  phx
    alex phx May 05, 2009
    Same here
The connecting pins have been flattened slightly by putting the plug on and off. i GENTLY squeezed the pins in an upward direction so they would make a better connection.
remember to be gently. when you fix this. do not dismantle the charger again.
Posted on May 12, 2009
Tv problem help
With the plug from the t.V. unplugged from the wall outlet, remove the tv cover. Follow the power cord to the power supply's printed circuit board. Look to see if there are any damaged, bulging or burnt out (exploded) capacitors. If there are, that's the source of the problem.
Be fore warned, even though the power cord to the tv has been disconnected from the wall outlet, good capacitors still hold (store) hi-voltages that can shock & even kill you; so don't touch them unless you know how to properly discharge a capacitor. Don't underestimate the power that these components store even though they are very small.
See this video 1st : http://youtu.be/AvlNKZ8GzEg
and this one as well: http://youtu.be/B41PeSDF_dk
Warmest regards
Mar 11, 2014 | Mitsubishi WD-60735 Projection Television
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
I have the 691tr-icc6 outlet/toggle. I would like the switch to control the outlet below it. So I can turn on and off the outlet as needed. , Where do I put the black and white wires that come to the...
You have switch plug combo with dark screws, brass screw, and silver screw.
Dark screws are for black Hot wire coming from breaker box.
Brass screw is wire going to Load that you want to turn on-off.
Silver screw is for white Neutral wire coming from breaker box.
To set up so switch controls outlet, you need 2 dark screws on one side of device that are connected by break-away fin.
Remove fin so dark screws are no longer connected.
One dark screw goes to switch, one dark screw to outlet.
Hot black wire connects to dark screw for switch.
Connect jumper wire from brass Load screw to the dark screw for outlet.
Connect Neutral wire to silver screw.
To test for Hot and Neutral:
Separate wires.
Turn power ON.
Test each wire to bare ground wire, tester lights up on Hot.
Hot is identified.
Test Hot wire to all other wires except bare ground, tester lights up on Neutral.
Mar 28, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Breaker tripped and now my nintendo wii wont turn on
Few things to try:
1. Different Outlet. Plug the console into a different outlet in your residence. If the Wii turns on, the outlet is dead. I would recommend an electrician to fix the outlet.
2. Try a different power adapter. You could purchase another power brick or get one from a friend and use the new one to try and power up the console. Also try in a different outlet (step one) to be sure
3. If none of this works, the console may have just received too much power and burnt out the power supply. Contacting Nintendo. Information below:
http://www.nintendo.com/corp/contact.jsp
Mar 06, 2011 | Nintendo Wii Console
My kinect isnt working ever since i got a hub at best buy and pluggd my xbox live and kinect cords together in it!
Make sure that the power supply is secure, and thencheck the power supply light.
Make sure that the power supply is cool.
Plug the power supply into different wall outlet.
Disconnect all accessories
Remove the hard drive
Request a repair
click here to download repair guide
Dec 29, 2010 | Microsoft Xbox 360 Console
If your laptop has a bad battery, will the computer still be able to turn on when plugged into a power outlet?
If your battery is totally drained or dead, your laptop will not turn on even when plugged in to power outlet. The power from the charger don't have enough power to pass through the battery that is trying to charge. Remove the battery and you will be able to turn on your laptop when plugged in directly to wall outlet.
Sep 21, 2010 | Toshiba Satellite M35X-S163 Notebook
The monitor went dark, seems to have no power.
Totally darken the room your computer is in, and see if you can see a very-dim image on your computer.
If so, it could be the "inverter" part inside the LCD that has failed (about a $20 part, but will take a technician about $50 to $75 to disassemble/replace/reassemble/test).
Try connecting the monitor to a different computer, to see if the monitor is OK.
Try connecting a different monitor to your computer, to see if the video-card is OK.
Jun 23, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Printer suddenly dead
It's possible the power supply died, however, there is a 3amp fuse on the slide in power unit that could have blown. I would check it before taking it to the recycling pile. If you mess with it be careful around capacitors, they'll hold a charge even if not connect to power for several days.
Nov 24, 2006 | Canon BubbleJet i560 InkJet Printer
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod - Black Logo
411 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
