Question about Proform 585 CS Treadmill
The belt problem silde with someone on it
When I try to use it, belt slide
Walk tread keps silding against maching and fraying belt
You should be able to adjust it on the end of the belt with some screws...tighten or loosen them...or one tighten and one loosen, Play with that and it should help you out.
Oct 16, 2012 | Bowflex Treadclimber
Restriction code for nokia 6500 slide please
If your mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 6500 silde mode mobile can be got at Mobile-unlocker.com which gives easy instructions to unlock your mobile.
Apr 18, 2012 | Nokia 6500 Slide Cellular Phone
How to grip /sild /flip it?
how to format nokia 6300
May 16, 2010 | Cell Phones
I have a nokia 6500 sild and its on 3 can give me a unlock code 4 ant netwok
in any nokia multimedia mobile install the software names MCODE available in mobile software websites
now enter ur emei no. when asked u will get a 1o digit code it will be ur new security code
NOW ENJOY
Jan 17, 2010 | Nokia 6500 Slide Cellular Phone
Printer is giving "Cannot find a document" error for slides
Same thing happening to me. Called Epson they said it is a hardware problem and that I could send it to one of their service centers to repair it. It would probably cost more to do this then buy a new one.
Sep 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
The silde to unlock will not unlock the i9 phone
Have you tried Calibrating your screen?
. There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out.
Apr 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Proform 585 CS Treadmill Logo
35 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
