Nakamichi bx 300 runs slow in play? Belts and idler have been replaced.
  • Audio Player... Master
  • 1,267 Answers
Need either Capstan motor adjustment with speed alignment tape or a new motor requiring the same alignmnet after the new motor.
Posted on Jan 18, 2013
4 Suggested Answers
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
Posted on Apr 23, 2008
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette Deck
Check leaf switches and also, press play -- after a few minutes, feel motor(s) for heat build up. If it gets hot, either motor is bad of something is preventing it from rotating
Posted on Apr 25, 2008
  • 11 Answers
SOURCE: My Nakamichi BX 125 won't turn the cassette.
capstan motor not working
belts slipping
Posted on Apr 13, 2009
Nakamichi BX 300 tape deck runs slow in play,belts and idler have been replaced
There is an adjustment in the motor that sets the speed however you need to have a frequency counter and speed alignment tape to adjust the speed correctly. There was also suppose to be oiling of the mechansm at the time the belts were put on.
Jan 05, 2013 | Audio Players & Recorders
I have a Nakamichi BX-300 cassette deck. The idler wheel assembly is broken. Where would I be able to find a spare?
Definitely the spare will be available with the nearest Nakamichi dealer close to you as you will need to check on your yellow pages or the net. But if there is no hope thenthe best way to go about is to identify the repair shop closer to you that has old sets, Youmay be lucky to find and salvage from an old set which would have the mechanism intact but with an electronic failure. Please search also on the site here for the NakamichiBX-300 models which had a serious failure to be bartered. hope it works out. Good day.
May 19, 2010 | Audio Players & Recorders
Transport Controls are dead
I have had the same problem with the CR-3A for about 20 yrs. I tried to get it fixed but nobody seems to have a permanent solution. Apparently the control motor (the one activating the leaf spring switches) over travels the worm gear after some time (poor design tolerances). I just open the cover and force it one way or the other until it works again - it will be good for a few plays and will happen again - a pain in the ****.
May 02, 2009 | Audio Players & Recorders
Apr 23, 2008 | Audio Players & Recorders
Apr 16, 2008 | Audio Players & Recorders
Nakamichi BX2 will not take-up tape and play
This may be a reel sensor problem, or the rotation of one of the reels is stopping for some reason. Most of the time, these faults are mechanical. There can be worn belts, or drive wheels, or gears, and etc. Sometimes there are faults in the electronics where a sensor is not being read properly.
The unit should be properly checked to evaluate the fault.
Jerry G.
Apr 06, 2008 | Nakamichi AV-10 Receiver
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
138 people viewed this question
 Grubhead
Grubhead
