Question about Verso Technologies VERSO 9128-A2-202-0SP Remote Access Server
The remote of my Verson blinks intermittently. It does not function when you try to open or close the car. It opens manually and start the car. Please help?
Toyota Version 2006 1.6 VVTI
  • 7,627 Answers
Battery dead?
Posted on Jan 06, 2013
ML 320 Remote Control doesn't function
Have you tried replacing the battery in it?
Jan 16, 2015 | 2001 Mercedes-Benz ML 320
Chamberlain remote garage door opener is intermittent
You probably have interference from somewhere. I had the same problem, turns out it was the LED light bulb I put in the opener. As a result, the door would always open, but hardly ever close. I called this intermittent, but there clearly was a pattern.
Dec 20, 2012 | Chamberlain Home Security
HOW TO RECONNECT INTELLICODE GARAGE DOOR CHAIN TO SAFETY CAM
please read carefully your owner manual, if you do not have a recommend to download from www.fitness.manualsonline.com or
www.manualsfactory.com
and proceed according with common sense
God bless you
Sep 09, 2012 | Genie Company IntelliCode GICT390-1BL...
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
My garage door opener opens fine from the wall unit and the remote, however closing is a problem, when closing the door from the wall unit I have to press and hold until the door is fully closed, if I...
You have a door sensor problem. The IR sensors found at the bottom of the door rails will need some attention.
Both have an LED visible. Is one on or none? If none are on, check the wiring. Older models had a plug in the rear of the sensor that corroded due to moisture, causing intermittent or no operation.
If 1 is on, check to be sure that they are aligned with each other. If they are crooked, the door will not close without holding the wall button (as you described). They are easily knocked out of alignment.
Check for cobwebs and debris blocking the sensors.
Replacement sensors are around $50 and are easily installed with just wire cutters and pliers. Remember to unplug the unit before replacing the sensors.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Auto tailgate warning light is on dash board but tailgate closed.
I have a similar problem, my tailgate stopped working with the outside handle and the remote but can be opened manually from the inside. I don't have an alarm so there is no problem with that but did you get a solution for the tailgate problem that I could try?
Jan 23, 2010 | 2004 Honda Accord
How do you set the garage door opener for a 2004 toyota 4runner LTD?
You hold the remote close to the three buttons on the vehicle. You choose which button you want the remote to transmit to, and you hold it down. With your other hand, depress the garage door remote opener, and hold it very close to the 3-button assembly. Wait for the red L.E.D. light to blink slowly. If it does not blink slow, continue moving the remote around, until it does blink slow. When it starts to blink slowly, stop moving the remote around. Wait until the light starts blinking rapidly. When the light blinks rapidly, the process is complete.
Oct 28, 2009 | 2004 Toyota 4Runner
Wont open when I press door opener. makes a clicking sound and reset light is blinking
I, PRESS THE REMOTE THEN UNIT START TO BLINK THE LIGHT. ALSO IT WORK WHEN HOLD THE MANUAL SWITCH TO CLOSE AND OPEN THE GARRAGE DOOR.
Oct 27, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Computers & Internet Logo
Top Verso Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Verso Technologies Computer and Internet Expert? Answer questions, earn points and help others
