Question about Roper RGX4634KQ Gas Dryer
Roper Gas Dryer not heating.
My roper gas dryer is not heating up at all. It is still tumbling just no heat. Also when I put it on the timed high heat cycle the timer knob does not move from where I set it. The other night it was on for over 5 hours and didnt budge. When I put it on the low hear timed option it does move....??? Any suggestions? Thanks
  • badrat71 Feb 13, 2009
    same problem as littlelizzie.  I can see the igniter glowing, intermittently the flame lights, but goes out.
  • 460 Answers
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need.http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx "Did I answer your question ?
Did it solve your problem?"
Posted on May 08, 2009
Dryer tumbles but wont get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Roper REX3614KW Electric Dryer
My electric clothes dryer will tumble but won't heat up to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Roper Dryers
I have a roper gas dryer and have replaced the thermal fuse twice, the dryer will heat and dry a load of laundry and then next time i try to use it the dryer doesnt heat what else could my problem be???
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 20, 2010 | Roper Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
My gas dryer stopped heating
I need your serie and model #
please
May 08, 2009 | Roper RGX4634KQ Gas Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Gas dryer problem
I am getting water in my vent hose. What could cause this.
Dec 13, 2008 | Roper RGX4634KQ Gas Dryer
Roper rgx4634kq2
Sounds like you broke a belt, which is very easy for some of us to replace. If your uncomfortable with gas call a repairman.
Manufactures place alot of safe guards on gas appliances. Please dont be afraid of it, gas is still more efficent at drying than an electric dryer.
Jun 05, 2008 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
Taking the back off the dryer towards the bottom in the center there is a white pc.of plastic about 3 inches long and 3/8" wide. Its clipped on the inside panel and has a screw securing it. It has two wires clipped to it.Thats the fuse ! I got a replacement form the local Sears parts store for about $15.00.
Oct 27, 2007 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
294 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
