Question about Bulova 96L90 Watch Bracelet Ladies - White MOP Dial
REPLACE BATTERY FOR BULOVA 96L90
What is the battery type?
3 Suggested Answers
SOURCE: I can't seem to remove
If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
Posted on Nov 22, 2009
mcnishl
  • 62 Answers
SOURCE: is the back of the
are there indents going around in a circle on the back of the watch? if so it is a screw off. You need a special tool available at a jeweler to unscrew back. If it does not have those indents, then look very carefully around the outside edge for the lifting spot, use a pocketknife (carefully!) to lift!
Posted on Aug 28, 2011
Battery size for bulova 98g48
If there is a dead battery in the watch, when it is opened, that is one way to identify the battery size.
A second way, if no battery left in it, is to go to a local jeweler or watch battery replacement kiosk at the shopping mall.
Third, contact Bulova at phone number shown:
https://www.bulova.com/pages/manuals-parts
Parts Manuals
Jun 15, 2018 | Bulova Watches
What size battery do I need for a Caravelle by Bulova watch C860429 ? Tks
Have the watch opened by a jeweler or trusted technician to see the battery type inside the watch.
Or: contact Bulova:
Bulova parts department at parts@bulova.com or call 800-233-3350.
You may also view or download a manual/PDF with information specific to your watch. Find the style number on the back of your watch case, then simply click on search icon at the top right, type in the style number, to find it immediately.
For all other inquiries or assistance, please contact service@bulova.com or call 800-233-3350.
Parts Manuals
Apr 13, 2018 | Bulova Watches
I need to replace Battery for C969908 Bulova Carvelle ? How, where, what's the stock number?
Take your Bulova Caravelle to a jeweler who, for a reasonable sum, will replace the battery.
Dec 03, 2016 | Bulova Watches
Which battery number should I use on a bulova 96t63
Most likely...
Bulova 228 = S05 American Watch institute, USA: 357 (303)
Japan: SR44W .. (SR44SW)
Possibly...
Bulova 606‎ = S32 AWI... Energizer/Duracell 377 or SR626SW
Which battery number may use in this watch bulova 96t63 thanks
and
Specialty Battery Finder
Jul 28, 2016 | Bulova Crystal Ladies 96T63"
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
My watch stopped working. I think I just need to replace the battery in it. how do I get the back of the watch off to do that?
Bulova Accutron watches were originally designed to use Mercury batteries of 1.35 volts, since they were the only type manufactured then. The pic (left) shows an original 214 all-metal "top hat" cell, before 387 cells with the plastic spacer became available. In most areas of the world, mercury-based batteries are no longer available, due to environmental concerns related to the safe disposal of them. The Tuning Fork watches manufactured by Esa (e.g the f300 Omega) were designed to run on either mercury or silver oxide batteries without any adjustment, provided the last repairer to work on the watch set up the index mechanism according to factory specifications.
It is strongly recommended that you do not replace batteries yourself, as special tools are required to open the watch case without damaging it. The only exception to this is the Accutron 214 model, which has a small battery hatch on the back.
Aug 24, 2010 | Bulova 26D08 Accutron Watch
How do I remove the back of my Bulova Accutron 98E09 watch to replace the battery?
mcdevito75 here, You will need a screwdriver to use in the slot for the battery cover or a coin, once you have the tool for the slot turn the cover just a bit and lift it off to get to the battery.
Jul 31, 2010 | Caravell Bulova Caravelle watch
Bulova Watch Millennia Motion 96B17 - stops - needs battery????
Dude, of course it stops during the night - it's a perpetual motion / kinetic watch. It doesn't have a conventional battery. When you move your arm (while wearing it), the natural motion of your arm will 'automagically' wind the watch. There's nothing wrong with it - these types of watches always have to be re-set in the morning if you don't wear it to bed (or you don't toss and turn in bed).
May 30, 2009 | Bulova Millennia World Time 98G66 Wrist...
I have a bulova 96b34 that has a rechargeable battery but needs a new one.the battery has a little welded contact on the back and i have no idea where to find one.
Batterie model is Panasonic MT920. You can order a Citizen part no: 295-5600 who is a rechargable batterie for watch mouvement Miyota model BR10. That mouvement is use in Bulova motion quartz, Invicta automatic and Citizen eco drive.
Jan 08, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Bulova 96L90 Watch Bracelet Ladies - White MOP Dial Logo
27 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
