Question about Pelikan Pelican Mystic Ride Snowboard
The adjustable toe bindings slip out the bottom.
The toe bindings slip out the bottom and act as a brake. What are we doing wrong?
  • 30 Answers
Nothing your doing wrong at all. Honestly you should just call Pelican and get your money back. those boards are all messed up everyone of them. people have tried to superglue, bondo and epoxy the problem binding but its really not worth it. I would recommend a fiberglass board over plastic. Its a heck of a lot more stable and they are still very reasonable price wise.
Posted on Jan 27, 2009
How do I adjust parking brake
If Disc brakes jack up wheels , make sure the cable is not binding or frozen , pull hand leaver on three clicks, adjust cable till brakes just start to bind, release hand brake and check the wheels are free to turn. Drum brake check cables are free, back off cable till slack, check lining to drum adjusters are free and adjust if need be, pull hand brake on three clicks, adjust cable so brakes just start to bind release hand brake and make sure the wheels are free to turn ,
May 27, 2015 | Cars & Trucks
Why does the rear brakes stay closed when on drive.I changed the brake pads,
both rear lock?
that be you did them both wrong?
there are adjustements that need to made
and checks,not just slam in pads
the FSM book covers how to do it right ever consider reading that first then act?
  1. pistons in calip, no seized,
  2. caliper slider pins seized.
  3. emg. brake, mechansim stuck
  4. emg, brake, not adjusted after all done, per FSM!
  5. brake pedal rod not adjusted, right for clearance to master cylinder (risks 4 wheel lockup)
  6. icing of parts, got ICE? we cant guess ice, and not stated.
  7. wrong pads, or put in wrong, or with shims wrong.
  8. more,sure,, why not get the brake man to fix this.> now since car is danger to all, you and others on road.
Jan 17, 2015 | 1996 Isuzu Trooper
Binding adjustment
There is (should be) a screw visible on each of the toe and heel pieces when looking down from directly above. That screw will adjust the height of the piece that clamps down on the top of the tabs on the heel and toe of your ski boots. For proper height measurement, use a credit card (or similar thickness card) and make sure you can somewhat freely slide the card side-to-side under your boot when it is in the binding and clamped down as when you are skiing. Too much play, and you will feel a sloppyness while skiing. Too little and you risk the binding not releasing properly caused by stiction. You can find demonstrations on YouTube also.
Apr 04, 2014 | Fischer Skis Fischer RC4 Z 17 Freeflex...
How do i square the table to the fence on a dewalt table saw?
Normally we adjust the rip fence so that it toes out 0.10 mm over the lenghth of the rip fence. Some models have to have the trunion shimmed or the table removed/adjusted to achieve this. The toe out ensures no binding but doesn't effect the measuring. Note. adjusting the trunion is a large job.
Feb 11, 2012 | Dewalt DW744X 10" Portable Table Saw
Should a caliper go bad after having an alignment & a standard brake job done on a 1999 dodge ram van
yes and no. a brake caliper could go out at anytime, but the majority of the time it will not go out after a brake job
Sep 16, 2011 | 2000 Dodge Ram 1500 Truck
Shifter & Brake pedal Specifications: I cannot get my toe under the shifter to do a toe lift shift, is there a specified distance between toe lift and floor board? Likewise, my brake pedal is so...
You didn't say what year and model your bike is but on all H-D bike the shifter position is adjustable. Take the bolt out and pull the shifiter off the splines. Mark it before you do. Change the angle up or down one spline and try it. If it's a Big Twin, sometimes you can get a bit of adjustment at the shifter reach rod as well. As for the brake pedal, there isn't a lot of adjustment but you can look at the return stop. Sometimes the bikes are equipped with a bolt that acts as a stop for when the pedal returns. Depends on the model of the bike.
Good Luck
Jul 21, 2011 | Harley Davidson FLHR-FLHRI Road king...
Atomic 4tix 310 binding toe adjustment.
Did you ever figure out how to adjust the toe piece? I am having the same problem
Mar 08, 2010 | Sport & Outdoor - Others
Replacing plastic strap that hold the toe cap.
You just need to remove the binding form the board and look underneath the binding. If it doesn't drop out by itself just lever the broken piece out with a flat head screw driver. Once this is done you can insert the new part screw on the cap strap
Mar 04, 2010 | Burton 07 Custom S Bindings Snowboard...
V1401 slips in all gears; what to adjust?
Take the top cover off,in front of you is the brake.Turn the mixer on and you will see it spin (put it in 1st gear),stop the mixer.on the right side you will see a pin that catches the brake flange,if its worn you can replace it,if its not worn then the brake needs adjusting as it acts like a clutch.Let me know,im a hobart tech band repair these units often.
Nov 18, 2009 | Hobart Food Mixers
Rear brake replacement
hi to get the pads in you did screw the calipers pistons all the way back and you should have backed the hand brake cable off as well then adjusted the cable afterwards problem with self adjusting calipers is you can adjust the handbrake cable and the brakes are ok until driven then they can bind so try backing the adjustment off on the handbrake [should really change both calipers as a pair to keep the axles brake balance but this is not anything to do with the brakes binding] best of luck paul
Oct 11, 2008 | 2003 Audi A6
Pelikan Pelican Mystic Ride Snowboard Logo
128 people viewed this question
Top Pelikan Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a Pelikan Winter Sport Expert? Answer questions, earn points and help others
