Question about Eljer 141-0220-00 Toilet Tank White
How to fix Water spraying straight up out - Eljer 141-0220-00 Toilet Tank White
Dishwasher spray arms
either the dishwasher is in "flood mode" and will fill then empty straight away- in this instance check for leaks in the base. or the wash motor is u/s and not pumping the water into the spray arms. poss jammed or seized, either way it will need a strip out.
Jun 05, 2007 | Kenmore 24 in. 15149 Built-in Dishwasher
Water is not coming thru the windshield washer spout, how do i fix it?
Simple: some times less expensive wiper solvent leaves residue in the outlet jets, using a straight pin, clean out the little jets, now it will spray.
Apr 03, 2014 | 2004 Honda CR-V
I have a Milwaukee paint sprayer that will not prime and stay primed. If I work with it I can get it to spray water sometimes and never paint. I tried to prime with it and had to water down the primer to...
I had the same problem. Turned out to be the hose clamp was loose and it was sucking air. I did not find the problem until I connected the garden hose adapter and pressurized the line. After the line was pressurize water was sqirting out at the from the hose connection on the right angle connected. Tighted the clamp and it primed without issue.
Sep 17, 2012 | Air Tools & Compressors
We have a model 4001 glass washer that won't stay constant with the heat Eric
Could be that the wash sprays are not going straight up or down to be recycled back into the wash tank. Thereby asking for more water to enter the tank from your supply which might not be hot enough at times. If the wash spray is not straight up or down then a lot of water will just go down the drain.
Oct 06, 2010 | Moyer Diebel 48 in. SW400 Dishwasher
Saeco magic deluxe is leaking water
Either two faults, one is that the boiler is leaking ( fix this straight away as water can spray on main circuit board and short out ) very costly to repair if both needs replacing. Second the water runoff to the front tray is blocked with coffee grime . Instead of the water left over when the brewer dissengages running off to the front tray it overflows into the machine. Hope this helps
Aug 10, 2009 | Saeco Magic De Luxe Espresso Machine
Problems in wet weather and cleaning my triumph won't start.
Water is getting into your ignition coils.
Trace the spark plug lead up to the coil.
Get some ignition sealer spray and spray loads of it on the leads and coil.
When a bike is new, it is sealed. After washing with detergents it gets washed away. Spray the leads and coil once a week to keep them totally dry.
An immediate way to get round when wet is to spray wd40 on the leads and coil, it should start straight away.
But, don`t spray ignition sealer on until it is totally dry.
Hope this helps
Jan 26, 2009 | 2004 Triumph Triumph Bonneville
Water not going in
This is a little late for the OP. But, I had the same problem over Thanksgiving of 2008. I searched online and saw that other people had the same problem, but there were no solutions posted. So, I paid $130 for a service tech to come fix the problem - maybe this will save you some time and money.
The solution was simple...pour boiling water (I boiled about a half gallon of water in a cooking pot) straight into the pump where the water sprays out of. You don't have to pull your dishwasher out and no tools are needed. Just open the door, pull out the lower roller tray, remove the bottom spray fin (just pull straight up), and pour the boiling water straight into the hole where the bottom spray fin was attached to. Next, put everything back in place, push the Power switch on, select a wash mode, and close the door. The dishwasher should start spraying water inside as usual.
The service tech told me that there are only two pumps in this dishwasher...one to pump the water in (the one that had the problem) and one to pump the water out. When you don't use the dishwasher frequently, the seal in the wash pump seizes up (sticks together). You can hear the motor humming, but the pump isn't able to send the water up into the spray fins. By pouring boiling water into the pump, it helps to break that stickiness and allows the pump to start sending water up into the spray fins. The solution is to run your dishwasher at least once a week. Even if you don't have much to wash, run a rinse cycle to let all the parts move and stay loose.
One other tip the tech told me is to pour a cup of white vinegar into the pump when you go away on vacation and the dishwasher won't be used for a week or more. This should keep the seals from sticking together. I haven't tried this yet.
Hope this helps.
Feb 20, 2008 | Bosch SHU9915UC Dishwasher
Eljer 141-0220-00 Toilet Tank White Logo
29 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
