Question about Panasonic AG-1980 S-VHS VCR
What is HO2 message is for? - Panasonic AG-1980 S-VHS VCR
  • Panasonic Master
  • 5,190 Answers
In many Panasonic models that means the tape did not withdraw when unloading. If this is the case then it could be the loading motor or mode switch that's the problem.
Posted on Jan 06, 2013
Where is h02 sensor on 99 4cl. camry
although the picture is of a 6 cly model the location is the same HO2 sensors are mounted in the exhaust system before and after the catalyst HO2..1 is the up stream Before the cat and HO2...2 is down stream of the cat if your code is bank one sensor 1 its the upstream and bank one sensor 2 is the downstream
Jan 03, 2013 | 1997 Saturn SL
How to repair the p1646
Looks like Lambda sensor fault,
Fault Code:- P1646 Indicates a Power-train fault
The fault is generally due to a problem in the Computer & Output Circuit area
Fault Description: ECM HO2 Sensor control malfunction -bank 1 upstream (1/1)
Action of ECM:- ECM Default:- HO1S 1/1 control circuit inhibited
After clearing the DTC, complete the Drive vehicle for 10 minutes
Check for a reoccurrence of fault DTC.
Possible Fault:- HO2 Sensor 1/1 heater failure HO2 Sensor 1/1 sensing circuit: short circuit to ground, short circuit to high voltage, open circuit ECM Failure
See http://www.bluejag.co.uk for more info
Aug 30, 2011 | 2002 Jaguar X-Type
How to remove a tape that is jammed in the vcr display showing HO2
I believe you might have a K-Deck model. If you enter "Panasonic K-Deck" into google you should find a loads of information including how to get a stuck tape out. If you can't post a message here and I can E-Mail it you.
HO2 on these decks means "Tape did not withdraw when unloading" the cause either the capstan motor, timing or mode switch.
Apr 16, 2011 | Panasonic Televison & Video
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
I have a 2005 GMC Savana G3500 and I need to know how many O2 sensors there are and where they are. Can anyone help?
Oxygen Sensor
CAUTION
The oxygen sensor in-line connector and
louvered end must be kept clear of grease, dirt or other contaminants. Avoid
using cleaning solvents of any type. DO NOT drop or roughly handle the oxygen
sensor.
The oxygen sensor may be difficult to remove when the engine
temperature is less than 48°C (120°F)
NOTE: Removal of the oxygen sensor is
easier when the engine temperature is above 48°C (120°F).
Upstream HO2S Sensor
To Remove:
  1. Before servicing the vehicle refer to the Cautions and
    Warnings at the beginning of this section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    • Electrical harness connector (A) from the HO2 S.
    • Remove the HO2 S (B) using special service tool
      J39194-B.
To Install:
CAUTION
GM uses a special anti-seize compound on the
HO2S threads. The compound consists of liquid graphite and glass
beads. The graphite tends to burn away but the glass beads remain easing sensor
removal. New or service replacement sensors have the anti-seize compound already
applied to the threads. If the sensor is removed from an exhaust component and
if for any reason the sensor is to be reinstalled the threads must have
anti-seize compound applied before installation.
  1. Coat the HO2 S threads with GM P/N 5613695
    high-temperature anti-seize compound as needed.
  2. Install the HO2 S using special service tool
    J39194-B;
    • Torque to 31 ft-lbs (42 Nm).
  3. Connect the HO2 S electrical harness connector.
  4. Lower the vehicle to the ground.
Downstream HO2S Sensor
To Remove:
    • Electrical harness connector (A) from the HO2S.
      J39194-B.
To Install:
CAUTION
    J39194-B;
Sep 23, 2010 | 2005 GMC Savana
It only gives me an error message HO2. Is this
THE SPINDLE THAT SPINS THE DISC IS FAULTY
Jul 17, 2009 | Panasonic Televison & Video
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
Display message HO2.
Hello, though I think it is a temporary solution you can try this:http://www0.dealtime.com/xPR-Panasonic-DVD-S35S~RD-228464823940 Best regards, Arpi
Apr 27, 2007 | Panasonic DVD-S35S DVD Player
Won't play movie. Message appears HO2.
Kindly say if the set just start rejecting your cds.or it have been rejecting them since you bought it then we can go from there.will be awaiting your reply you can email me at nicodhem@yahoo.com
Apr 03, 2007 | Panasonic SC-HT810V System
Panasonic AG-1980 S-VHS VCR Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
