Electrolux EOB6632 Electric Single Oven Logo
mike scan Posted on Jan 05, 2013
Oven cuts out during cooking
Cuts out when hot starts again after a while
2 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 01, 2008
SOURCE: The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on May 15, 2008
SOURCE: Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Temp change during cooking zanussi ZOP37922
Both gas and electric ovens will cycle on and off throughout the cooking cycle to maintain the set temperature. When the oven temperature has dropped below the set temperature, the oven cycles on again to provide heat and will cycle off again once the temperature is higher than the set temperature.
Thermador oven preheat light comes back on during baking session. Oven doesn't stay hot enough to finish cooking food.
Get it repaired from authorised personal. Seems sensor elements has gone down or programming chip is malfuctioning.
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
1helpful
I have a Frigidare oven. It keeps turning off during use. What would cause this?
If this ocurrs during cooking it's most likely a safety cut out stat.
My cooker keeps switching off during cooking even when the timer is not set, the grill does the same
depending on the make some ovens have a thermister where if the oven gets too hot it will cut out untill it cools back down, possibly the thermister is faulty.
Apr 06, 2010 • Ovens
Candy double oven purchased 14 months ago. Bottom oven cut out during cooking. Fan and light works no temerature though
It's most likely to be the oven heating element that is 'gone'. You will need to have it replaced.
Jan 08, 2010 • Ovens
3helpful
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
2helpful
Top Electrolux Ovens Experts
john h
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
