Question about Cameras
Where's the altanator tensioner on a 04 Chrysler Sebring v6 3.0
    Top Expert:
  • Cameras Master
  • 76,682 Answers
Go here and buy access to the factory manuals. www.alldatadiy.com
Posted on Jan 05, 2013
2000 chrysler sebring had battery light on yesterday. Door won't even lock with the key.
Most likely the battery, jumpstart it and confirm it runs after you take out the cables, if it doesn't, then its the altanator.-- cheers
Sep 29, 2016 | 2000 Chrysler Sebring
How do I fix grinding whinding noise on 2009 Chrysler Sebring
Hi, That sound maybe coming from the power steering pump. Check oil level and check belt tension. It maybe time for a new belt.
If noise presists see you local mechanic for further help. Good luck.
Dec 15, 2014 | 2009 Chrysler Sebring
2004 sebring won't start at all
sounds like you might have lost the altanator. Check the battary to see if it is very low, if so it was running of the battery and not the altanator. try charging the battery and see if it will run. If it does, checkthe voltage on the battery. it should be above 13 volts when runnig.If not it is the altanator.
Sep 15, 2012 | 2004 Chrysler Sebring
Im tryin to find out how to let tension off serpatime belt on 2000 chrysler sebring convertible
Depending on which engine you have, there should be a spring loaded tensioner pulley that you move with a large breaker bar. The tensioner should have a 1/2 inch drive square hole or a bolt for a socket.
Jul 28, 2012 | Cars & Trucks
Tensioner location on 97 chrysler sebring 2.5L 6 cyl
The tensioner pulley looks like an idler pulley, only with an adjusting bolt protruding out about 2 inches from just behind the pulley. Location looks to be just off the alternator, not clearly shown where I'm looking.
To loosen belt, you loosen the tensioner pulley nut, and then turn the adjusting bolt in to relieve tension. When putting the belt back on, adjust tension with adjustment bolt, then tighten the pulley nut. This is for Sebring Coupe, Convertible is different. Good luck.
Jun 22, 2012 | Chrysler Sebring Cars & Trucks
How do you release pressure from the tensioner to remove the timing belt on a 2006 chrysler sebring?
it should be on a spring loaded arm that applies tension from that to the belt. on the arm the is a spot where you can use a 3/8 inch socket wrench to reverse the tension and remove the belt.
Feb 10, 2012 | 2006 Chrysler Sebring
Were is the belt tensioner located on my 08 chrysler sebring 2.4 l
Apr 06, 2010 | 2008 Chrysler Sebring Convertible
How can i get the idler tension to loosen up to cange my belt on my 2006 sebring
you loosen up center locking bolt bolt of tensioner pulley.there is a bolt next to tensioner pulley you turn the adjusting bolt to achieve the proper tension.
Dec 13, 2009 | 2006 Chrysler Sebring
Belt came off 1998 chrysler sebring lxi
you have two belts . put the large belt on first . it goes around crank pulley air conditioning pulley alternator pulley.loosen tension pulley to adjust belt. tension. then you put the other belt on power steering pump pulley and crank pulley. adjust belt tension loosen power steering pivot bolt. that it.
Mar 16, 2009 | 1998 Chrysler Sebring
04 CHRYSLER SEBRING REAER BALL JOINT
it is part of the control arm simply unbolt the arm and remove it
Feb 03, 2009 | 2004 Chrysler Sebring
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
