Question about Kohler Plumbing
Kohler a112.18.1 diverter will not spray
Water will not spray from the kitchen faucet spray hose
Generally the sprayer trigger assembly will unscrew from the hose. You can then point the hose toward the sink and turn on the
water. It should flow freely through the hose when either the hot or cold is on. Generally there is a aerator on the spray head. You can access it by unscrewing the tip of the sprayer assembly and clean out any mineral deposits. There may also be an inline type filter in the handle where it screws onto the hose that can be removed and cleaned. If this doesn't help I would guess the on-off triggering assembly is broken and you would have to replace the sprayer head.Hope this helps.
Posted on Jan 05, 2013
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
meBNme
  • 334 Answers
SOURCE: side spray has very low pressure
Disassemble the sprayer and remove the dirt and dibri gathered inside.
Reassemble.
Has the water been turned off to that faucet, or the entire home recently? If yes, it probably loosened sediment in the pipes and its clogging the sprayer.
Posted on Dec 06, 2008
dragonsthatk
  • 547 Answers
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Posted on Feb 26, 2009
bearsfan7538
  • 119 Answers
SOURCE: Trying to fix leak on kohler fairfax kitchen
You need to remove handle and cartridge and spout should come off to replace the rest very common leak
Posted on Nov 15, 2009
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
How do I replace a hose diverter in a single handle Kohler kitchen sink?
Yes, contact Kohler and they have a site you can watch that should be helpful.
Jan 11, 2013 | Kohler Home
How do I remove a diverter from a kitchen faucet
small alen set scew remove on handel,sometime there is a decorativ plug on top remove first then remove nut below that and deverter should be under it.
Jan 21, 2011 | Kohler K-10416-BN Fort½ Single Control...
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: Fort® Single-control...
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Plumbing Logo
1,550 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
