Question about Vtech VSmile VMotion Wireless Controller
My vsmile controller will not turn on. we put new batteries in it and it seems to not have power. any ideas
  • kristiem102
    kristiem102 Jan 05, 2013
    its a wireless controller we are having trouble with
Any ideas on how to get my Vtech Vmotion controller to connect again?
take the batteries out of console. Hold the start button for 45 seconds. Put the batteries back in. Turn console back on. Controllers should work now.
Nov 14, 2011 | Vtech VSmile VMotion Wireless Controller
My wireless controller on a vtech vsmile motion is not talking to the game. it has been a really long time since it has been played. new batteries are in. do I have to reprogram? couldn't find the...
take batteries out of console. Hold start button on console for 45 seconds. put batteries back in. press start to turn console on. controllers should work now
Jul 19, 2011 | Vtech VSmile VMotion Wireless Controller
Joystick not responding on the controller - any ideas on what to try?
take batteries out of console. hold start for 45 seconds. put batteries back in. restart console. controllers should work now
Apr 15, 2011 | Vtech VSmile VMotion Wireless Controller
The controller will not connect and its brand new out the box
Vmotion control stop working? Here is the solution: Take the batteries out of the console. Hold the start button (green) on the front of the console for 45 seconds. Put the batteries back in. Turn on the console. Controllers should work now. Good luck. It worked for me :)
Dec 30, 2010 | Vtech VSmile VMotion Wireless Controller
I have plugged the v tech in to the tv and put batteries in the bottom but nothing works
This system can be frustrating because if you don't do things in the right order, it won't work. I wrote the instructions in permanent marker on the side of mine. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in.
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work you may have to take the batteries out and it seems to clear and then follow the steps again. It is easier to buy an adapter instead of batteries so if you need to clear it you just unplug it and start over. Good luck!
Dec 30, 2010 | Vtech V.Smile TV Learning System
V tech tv learning system will not turn on
this system is frustrating because if you don't do the steps in the right order it won't work. Start with the TV and Vsmile OFF.
step1) put the cartridge in and make sure it's all the way in
If it still doesn't work you may have to take the batteries out, or unplug the adapter, whichever power source you are using, to clear it and then start the steps over. Good luck!
Nov 15, 2010 | Vtech V.Smile TV Learning System
My Vtech vsmile didn't work a the time I push the power button never happend my batterie are test and are brand new an i try to connect direct with a power supply never work again
There are problems with the power adaptors. Did you use a VSmile power adaptor, or something that just seemed to fit the unit? Using the wrong power adaptor (like unknowingly plugging a Leapfrog power adaptor) into the unit can cause damage to the Vsmile Board.
Push and hold the power (smile) button for one minute, then install fresh batteries. if it powers back up, then try:
Dirty Smartridges (the game cartridges) are to blame for about 90% of VTech Vsmile products not powering up.
In some instances, the cartridge slot on the unit itself can become damaged and will cause no power up.
Kids (of all ages) can dirty a smartridge in less than a second, and render the whole system dead.
Sep 30, 2010 | Vtech V.Smile TV Learning System
V tech new item..motion console..worked..turned it off turned it on..wont work
make surt you did the steps in the right order. Start with the TV and Vsmile OFF.
step 1) put the cartridge in and make sure it's all the way in
if it still doesn't work, try taking the batteries out or unplug the adapter to let it clear and then try the steps again.
Nov 23, 2009 | Vtech V.Smile TV Learning System
I cant get the bloody controller working, and just have an anoying, little thing come on, repeating vsmile, drives me nuts, what am i doin wrong? brand new system!!!! helllp me!!!
Make sure the controller doesn't need batteries, and make sure it's plugged into the proper input on the vsmile system. If it's permanently attached to the vsmile system via a wire, then you may have a defective controller/vsmile and you should take it back and exchange it for another one.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Toys
Vtech VSmile VMotion Wireless Controller Logo
57 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
