Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My oven is giving me an F 3 error
I cleaned my oven with oven cleaner and now am trying to bake something but keep getting an F 3 error.
  • annaraenkim Jan 20, 2009
    Okay, so do I just wiggle the sensor around or what. It worked before I cleaned my oven.
  • nancyiram Jan 26, 2009
    Can you please tell me where i can find the oven temperature sensor at on my kenmore electric stove which gives me an F3 error message.
  • 1,800 Answers
An F-3 error message usually indicates a problem in
: the oven temperature sensor or its wiring circuit.
Posted on Jan 19, 2009
No manual. Hit the clean button and 15 minutes it caught on fire. Hit the cancel
It probably caught fire because to much crud was built up inside probably from not cleaning often enough. I assume there were not flames but just a lot of smoke, try again but watch it carefully. Some ovens are damaged by oven cleaner so I would get a manual first to be sure using that would be OM.
Here are some links that may help:
How to Clean Oven Naturally with Baking Soda Tutorial
How To Clean an Oven With Baking Soda Vinegar Cleaning Lessons from The...
Mar 02, 2015 | Ovens
How can we clean the baked on food from the oven racks and rack holders? Stainless steel cleaner does not touch it.
To clean the stainless steel without marking it you can first try non-caustic oven cleaner, if you use normal oven cleaner the acid in the cleaner will etch "eat" the surface of the stainless steel
May 05, 2011 | Electrolux 30" Built-In Single Electric...
How to clean oven model JSP46D P1BB
That model is self cleaning . So you have to remove the oven racks and press the button marked self clean. The self cleaning cycle will last anywhere from 2-4 hours . once the oven unlocks after the cycle is over you have to wipe the surface with a clean clothe. It is very important to never use regular oven cleaners (i.e. Easy Off ) in a self cleaning model. If you need to spot clean something without using the Self cleaning mode you can make a paste of baking soda and water and let it sit for an hour before wiping.
As far as the top is concern, use a mild soap and a dish cloth on an everyday basis. There is products specifically designed to clean the ceran tops (good brands are "Cerama Bryte" and "CookTop", they are available at any Wal Mart) you should use one of those cream cleaner at least once a week. If something is really baked on , you can use a razor blade ( same ones ones used to removed paint off windows) or a scotch brite pad ( the blue one only.. the yellow one is too abrasive)
Mar 14, 2011 | GE Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    Trying to get gas self clean/oven to start. Getting error E1 F5.
    E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
    Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
    You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
    Nov 26, 2009 | Ovens
    Foil baked onto oven base.
    Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
    Jun 07, 2008 | Ovens
    Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
    Top Kenmore Ovens Experts
    Dan Webster
    Dan Webster
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
