Question about Samsung SyncMaster 215TW 21" LCD Monitor
How to fold SyncMAster 215TW stand ?
Hoxw to fold the stand, so that I can move the monitor into its box ? The stand lifts on its own, making it too large to fit in the box...
  • 19 Answers
SOURCE: Monitor syncMaster 913v
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: My Samsung SyncMaster 215TW Monitor
If it is not still covered under warranty, start by opening the case. Once you remove the power board, you will probably notice several capacitors (the round, can shaped parts) that have tops that are not flat. If you see any that have bubbled tops instead of being completely flat, they need replaced. Once they are replaced, the monitor should turn right back on. Hope this helps.
Posted on Feb 20, 2009
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
SOURCE: Samsung syncmaster 215tw monitor flickering
The capacitors BigTech referred to are C110 & C111, 820uf-25V Electrolytic, on the power supply board.
With minor soldering skills, you can replace them with Radio Shack in-store capacitors, Stock # 272-1032, 1000uf-50V Radial Lead Electrolytics for $1.59 each. Works great!
Four bucks and little bit of time saves the monitor.
Posted on Jul 08, 2009
budmrtn
  • 11361 Answers
SOURCE: stand for the monitor on a samsung syncMaster 940n broken
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 29, 2010
Which type of screws
Usually you rummage through your old screw dish/box and find one that fits. Threads for plastic - course. Threads for metal - fine. Check the length.
Aug 20, 2014 | Computers & Internet
Samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Jun 07, 2012 | Samsung 215TW SyncMaster 21" LCD Monitor
My Samsung SyncMaster 215tw stays in power saving mode with the blue power button flashing and won't turn on.
I'd verify all the cable connections first.
You could be dealing with two different problems, bad monitor, or a bad videocard/pc.
I'd swap the monitor out to verify that the computer is working as it should first. Once you determine that the PC is in fact fine, my suggestion would be to change the resolution on the PC to a lower setting then normal. Once that is done Plug the Samsung SyncMaster 215tw back into the pc and see if it powers on.
If it does not, i'd check the cables and swap them with something else to make sure thats not the problem. If you have another PC available, i'd test the monitor on that PC to make sure that it is not the issue.
After all that you'll come to the determination on what the problem is. Sadly, if the LCD is bad you'll have to replace it as they are extremely expensive to repair and generally not worth it.
However, i'd verify if it is under warranty or not, you never know! you might be able to get it fixed for free :D
Mar 01, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
Monitor blinks on but goes blank
seems to be the same problem as I got with the syncmaster 215tw
Feb 01, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
When I play some games on my syncmaster 215tw, the screen goes black after 5 minutes. I have to reboot everytime to get the screen back on. The blue light flashes but i cant do nothing until i reboot....
that means your VGA is not big enough to run the game.This problem is not from the monitor but your system.I suggest an upgrade in your system to enhance better performance.
Aug 02, 2010 | Samsung SyncMaster 215TW 21" LCD Monitor
Changing rear shocks
Surprising not to have a centre stand fitted to a tourer, however it can be supported on the frame rails beneath the motor if weight is distributed over a large area and balanced. A sturdy crate or stand is required and someone to help you. A moveable ramp or block and tackle for front wheel is easier to lift and keep steady.
Apr 19, 2010 | 2008 Triumph Rocket III Touring
I'm attempting to repack my AL2216W LCD Monitor into the original box. When I slide the two foam protectors on the ends, it won't fit into the box. The stand is in the way no matter how I position the foam...
Of course there is a trick to this. Remove the stand by pushing gently on the clip at the bottom. I usually turn it upside down to do this. Then lay the stand on top side of the foam.
Please rate this answer as the only thing I get for answers is a rating.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Samsung SyncMaster  215TW 21" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
