Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Brown leakage there is brown liquid leaking from under our refrigerator. Our tray underneath is not anywhere near full.
  • 410 Answers
I've got a possibilty for you. moisture will build up in the cabinet of refrigs and then cause a little bit of rusty water that will leak out onto the floor. you could also have a plugged drain essentially causing the same thing to happen. look under you veggie bins for water build up. hope that helps. peyton
Posted on Jan 20, 2009
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Thick brown liquid at leg of of refrigerator
the thick brown liquid is decomposing moss, from the condensate inside the unit finding a way out.(think of it as the same stuff you get around a shower tray)clean out the fridge using clorine bleach and dry thoroughly....leave the door open for the clorine to gas off otherwise it will taint the food.when the smell has gone then close door and switch on.(some people use milton fluid,but clorine kills all known germs....)
Jul 16, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water leaking from underneath right side of refrigerator. Shut off water line to ice maker and still slowly leaking. Where is this coming from?
check the defrost drain line and catch tray under the fridge. you may just have moved the hose out of the tray or the tray may be full.
or it could just be your water valve has a slow leak. try turning off the water farther back on the supply line.
Dec 12, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Water is leaking onto the floor from underneath the refrigerator.
There is a condensor tray located underneath. It catches water and then the water evporates. Sometimes the tube gets plugged and causes a mess. Check the tube and the condensation tray. You can access the tray by just taking off the grille under the door on the front of the refrigerator.
Nov 17, 2009 | Whirlpool EL7ATRRKS Refrigerator
Brown leak near the front foot
Condensation tray has been clogged up this tray sits on top of the compressor to evaporate the condesation from the unit. this tray sits on the compressor to use the heat of the compressor to evaporate the water produced during its cycles
Aug 21, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Kenmore model 88892 sxs refrigerator started to leak water on the bottom underneath of refrigerator. I cleaned all lint and debri underneath, but still water coming out on floor. Dont their suppose to be a...
There is a tray that is in the bottom, remove the cover thats located just under the doors in front. You will see it most of time black in color and it will be easy to pull out be careful for it will be full. Its from condensation most the time in the summer this happens really no problem. if thats not it check the ice maker water supply line that could be it also.
Aug 09, 2009 | Refrigerators
Bad smell in tray at rear of fridge
maybe you could use a wet/dry shop vac to clean it out
Jul 30, 2009 | Refrigerators
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
1,426 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
