Question about Whirlpool Dryers
Dryer is working but no heat
The dryer is functioning however there is no heat to dry the clothes
  • 429 Answers
Electric? Check the heater element then the thermal fuses or on the newer units, thermastats
Posted on Jan 05, 2013
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
Illeagle
  • 525 Answers
SOURCE: my dryer wont heat up when it drying
Your issue is as follows:
"the dryer works but there is no heat to dry the clothes. model no/stock no- 86983100-69831 kenmore ultra fabric care soft heat dryers"
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is invalid. I have provided some common solutions to help guide you in your search.
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
This information is for an electric, generic model dryer only!
My Solution is:
If your dryer doesn't heat, check these:
Temperature Switch; make sure a positive heat selection has been made, if still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 17, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
  • 686 Answers
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Posted on Feb 17, 2009
  • 6 Answers
SOURCE: dryer working but no heat
Your dryer has two separate fuses, one to turn the drum, and one to heat it. It sounds like you have a broken fuse. Unless this is a new installation, then you need to make sure you have the proper electric cord attached. If it's mistakenly connected with a range cord, it won't supply enough power to the dryer.
Posted on May 20, 2009
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Kenmore Elite Clothes Dryer working but not drying
First take dryer vent hose off and check for a plugged vent, clean it all out. There is either a clamp on the hoses you take off by prying or with a screwdriver, should be two one at the dryer and one at the vent to exit the house, also make sure that there is nothing blocking the door on the vent that exits the house sometime animal like to build nests there. If this does not fix the problem it could be the heating element in the dryer, sometimes it is cheaper to just replace the dryer than the element
May 21, 2012 | Kenmore Dryers
MY WHIRLPOOL DUET DRYER IS WORKING BUT NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
The dryer is not drying. The drying temperature
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 19, 2010 | Kenmore 500 6952 Dryer
MODEL PBSR353EWOWW. Dryer is functioning but...in
One or more of your heating elements is probably out.
I have a repair album with photos and a manual HERE
Jan 14, 2010 | Dryers
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
