Question about Tascam DP01 All-In-One Recording Package Microphone
Re: Tascam dp-02 8 track digital recorder been using for over a year no problems and having fun right up to today ... was adding a track to a song when i did a "punch -in" with the guitar (which i have done numerous times in the past) however i must have hit the stop/play/record buttons together at the same time by accident and now i have locked up the recorder - the message it gives is "NOT STOPPED" which the manual says i must have hit the wrong button by accident and the "transport" isn't stopped - so i push "STOP" and it remains locked up ... can reverse, can fast forward, but can not play/record/load another song or even turn the recorder off bacause the message again pops up and says not stopped - help (i know how to do a restart but having done that once a person will lose All of their songs)
  • Anonymous Mar 14, 2009
    Stop button will not work. After I hit play, I cannot stop, or even power down without uplugging. I have tried resetting, but to no avail. DP-02
  • Anonymous Mar 15, 2009
    Yup twice tonight
It happens all the time to me. Only solution is to save constantly as you record because once it freezes up and says not stopped you can only unplug and plug back in then turn power on. You will lose what you were recording but nothing will be lost that you have saved.
Posted on May 12, 2009
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Overlaying one track onto another
Maybe Tascam can supply information for this.
Jul 07, 2014 | Tascam DP-02 8-track Digital Portastudio...
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Nov 11, 2009 | Tascam Dp-02cf Digital 8-track Recorder
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
DP 02 Info
Can't help you with any books for the DP 02, but I can try to assist you in doing what you'd like to do.
The way I would attempt to do this, and there may be other ways but this is really the cleanest in my opinion, (assuming you have access to a computer) is to first rip the CD onto your computer into a series of wav files. Then you'll want to work with one song/CD track at a time. Then you'll need to use a WAV editor (Audacity is a good free one) to convert the wav file from STEREO into MONO wav file. You can then (using the USB import function on the DP-02) import the mono WAV file into the DP-02's fat partition. From there you can load it into the DP-02 by choosing which track to load it into. You'd then be able to play this track while recording your voice overdubs onto another track.
You'd then mix your song and you could burn onto a cd right from the DP-02 (or do as I do and export the mix as two mono wav files back onto your PC and, then convert them back to stereo and when you have all the songs you want for the CD burn a new CD from your PC).
You may have to consult the manual for how to use the USB import/export as well as how to record and mixdown, but I've tried to outline the basic process to do what you want which wouldn't be discussed int he manual.
Hope this helps.
bd
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam DP01 All-In-One Recording Package Microphone Logo
387 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
