Question about Magic Chef MCWC44DZ Wine Cooler
Stuck in Stand by mode on MCWC44DZ - Magic Chef MCWC44DZ Wine Cooler
Hold the lower zone (right side) temperature up and down arrows until it comes out of standby mode.
Posted on Jan 15, 2013
Acer stuck on preparing to stand by
I would force power off, (press and hold down the power button) then start up windows and download any updates that are missing and then use the Shut Down command instead of the Stand By/Sleep mode.
Sep 11, 2014 | Computers & Internet
Laid on side, how long wait before plug in?
if there are tubes coming out of the compressor on the side that it was laid over on, then give it 24 hours just to be safe, if no tubes plug it in and let it run
Feb 05, 2013 | Magic Chef MCWC44DZ Wine Cooler
Need to order PCB for Magic Chef wine cooler MCWC44DZ
Go to this page it will take you to a "dropdown" menu. Go to your model number and there will be 2 different PCBs in each category. One is for the door the other is the main. make sure you get the right one....match up the numbers you mentioned 155TD in yours which is the "pren" version of the 2 choices. Hope this helps you! http://mcappliance.com/partorder.aspx
J
Jun 27, 2012 | Magic Chef MCWC44DZ Wine Cooler
I Have a Magic Chef MCWC44DZ and it is reading 82 for both zones. When i try to set it back to the normal temps it just locks up and goes back to 82
try to reset your unit unplug it then after a several minutes plug it on then observe unit. check your condensing unit the fan motor if working smoothly or clean your condenser possible dusty. use pressurized water. adjust your thermostat setting.then observe it.
Mar 10, 2011 | Magic Chef MCWC44DZ Wine Cooler
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Jul 06, 2010 | Audio Players & Recorders
My Sony KP-51WS500 is stuck in Stand by mode
Have you tried unplugging the TV for a few minutes? if it's some kind of computer error, unplugging it will allow the error to clear and possibly allow the TV to work again. Just an idea.
May 22, 2010 | Sony KP-51WS500 51" Rear Projection...
Magic Chef Wine Cooler Model MCWC44DZ Where can I
On the Magic Chef site you can order parts for the cooler. I took mine out and treid to find them on the web somewhere else and could not locate them anywhere except China and England. I know this isn't true but tried every search option I could think of. They are about $22 plus shipping (HIGH). You might try the following: http://www.fixya.com/support/t1814377-magic_chef_mcwc44dz_e4_error
May 04, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Magic Chef MCWC44DZ Wine Cooler Logo
483 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
