Question about Rival CF275 Deep Fryer
How do I remove the portion that holds the oil to clean?
How can i remove the cylinder from the actual deep fryer body, so that I can empty the oil and clean it?
If I remember correctly, the manual that came with mine said that it is not removable. Pour out the oil and wipe the interior with a paper towel. (I wish it were removable!)
Posted on Jul 01, 2007
Have to unscrew it and remove it. Havent tried it yet, but it is so dirty inside, I do need to try it.
Posted on Sep 01, 2008
How do you empty the grease?
There's no really easy way. Let the oil cool. Place a piece of foil over one side of the rim and then use a ladle to remove as much of the oil as possible. Then remove the foil and quickly invert the fryer, not giving the last of the oil a chance to get around the edge of the rim. Wipe the rim with a paper towel before turning it right side up. Doing all this over a piece of newspaper help to control the mess.
Aug 28, 2014 | Sylvania Cool-touch Deep Fryer 1 Liter...
Review Miroil P36 B FryPowder
Oil wears out and gets contaminated. If you overload the fryer the temperature will drop and your food will adsorb it and contaminate it. Watch the temperature when you load it, I had a limit of 10F drop. Pre-cooking your frozen items will help a lot. I would replace the oil on a weekly basis depending on your volume. Empty the fryer, clean it and filter the oil every day. This will help a lot.
Mar 26, 2014 | MIROIL P36B Frypowder 240ml Portion Pack...
Oil leaking from the bottom of fryer
Do you let in from hot to cold that might do something to it. Need anew one
Feb 09, 2013 | Rival CF153-WM Deep Fryer
How can i clean my Tefal maxi fry deep fat fryer
Hi there, the best way I have found to clean a deep fryer is to empty it of the oil and fill it up with 1/3 water and detergent, turn it on but dont close the lid, or if you do close the lid carefully monitor it otherwise it will spill over and let the water boil after about 10mins turn it off and wipe away the ****, empty the water out fill it again with just water, same again for 10mins, empty it and wipe it clean with a cloth
Jan 10, 2012 | Tefal Kitchen Appliances - Others
How to clean oil and empty oil out of oleoclean deluxe fat fryer
Hi there.
For the best manufacturer's recommended cleaning procedure, you can download owner's manual for your fryer at http://www.tefal.com.au
Regards.
Aug 16, 2011 | Tefal 6147 Superclean Maxi Deluxe Deep...
How best to store the fryer - with oil? if so, with fryer basket in oil?
It is best to empty the fryer and store the oil in a sealed container...also clean the basket and the fryer is they are not going to be used for more then a couple of days...
I have left them for a couple of weeks and things get really nasty...
heatman101
Sep 12, 2010 | Moulinex Kitchen Appliances - Others
Can you remove the bucket (part that holds the oil) on a CF153 ?
It should come out, because you may have to replace it one day. You may find the screws for it on the bottom side of the vat. Does it not have a spout at the bottom of it ?
Feb 13, 2009 | Rival CF153-WM Deep Fryer
Emptying the deep fryer
Ther below taken straight from the RIVAL web site.
Remove the oil bowl by lifting the bowl straight up out of the plastic exterior. To replace oil bowl, be sure the brass guide post (between the 2 electric prongs on the bottom of the bowl) is aligned properly with the center hole of the receptacle in the bottom of the housing. The brass guide post should guide the electric prongs into the correct position. Firmly press on bowl to ensure it is positioned properly. Lid should close tightly.
http://www.rivalproducts.com/help.aspx?helpNav=1
Dec 26, 2008 | Rival CZF625 Deep Fryer
HOW TO DRAIN THE OIL?
it should be in the front of the fryer after opening the front door there is a 3/4 drain valve
Sep 16, 2008 | Vulcan EF3 Deep Fryer
Taking out the oil?
I am almost positive that you will have to lift the whole thing to empty the fryer. It looks as if it is one whole piece.
Jul 11, 2007 | Rival Wing-It CF160 Deep Fryer
Rival CF275 Deep Fryer Logo
576 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ellenskitche
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
