Question about Microsoft Xbox 360 Elite Console
3f45 0000 0080 0300 d000 0185
Cannot download update and this is the status code...any help?
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Jun 13, 2014 | Microsoft Xbox 360 Console
Xbox360 update download failing
This usually happens when the Xbox does not have enough space to save the update to in order to install it. Make sure you clear out enough space so you are able to properly install the update.
Here is a list of other errors that can happen to system updates.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Contact back with the code you get if you cannot fix it using Microsoft's tips and I will try to help.
Apr 08, 2014 | Microsoft Xbox 360 Console
Status code 3cd6-3f45-b680-0f00-c000-0034 xbox
try holding the sync button in on your console and power the console up do not release the sync button until the console has fully booted up if not try calling xbox they can usually walk you through this problem
Nov 21, 2012 | Video Game Consoles & Games
Its give me a status code
Hello Mark Swift,
It seems as if the status code "3151-351f-b800-0402-c000-016b" is an error code resulting in a failure of receiving an update directly into the cache of the console. This also may be the cause of trying to install custom firmware. I cannot guarentee this will work, but try downloading the Xbox update from Xbox.com onto a CD and inserting it into your Xbox console to download it. If this does not work, message me back, I will keep track of this problem.
P.S. I cannot provide you with a direct link to the update because Xbox.com is not working on my laptop wirelessly. Sorry!
Dec 05, 2011 | Microsoft Xbox 360 Console
Xbox 360 support status code 3151-335A-B800-0F00-C000-0013
The update was interrupted, the best way to clear that code you must update your system manually. got to xbox.com/support and download the latest update files. use a USB drive to finish the update loop.
thanks
www.1RepairStop.com
Sep 14, 2011 | Microsoft Xbox 360 Console
Cant process update status code 3080-351F-1380-2203-C000-0001
Is your xbox modded? if it is then you must update your customer firmware then finish the update loop.
If its not then go to xbox.com/support and download the latest update files and use a USB to finish the update
Thanks
www.1RepairStop.com
Sep 10, 2011 | Microsoft Xbox 360 Console
I am getting a status code after trying to download the system update from Xbox. The status code is 3151-335A-1380-2203-C000-0001. What can I do to get around this?
You buy that Xbox used? 3151-335A-1380-2203-C000-0001 is the reference code for an Xbox that has been modded and/or hacked. Basically if the seal in the Xbox has been broken and now you are pretty much SOL.
May 26, 2011 | Video Game Consoles & Games
Update failure; system status code. 3151-0000-D080-0200-8007-045D. What I've done: Cleared HD cache... no joy. Removed wireless and switched to cat5... no joy. Connected directly to Modem...
I can't really find anyone who has been able to fix this issue. Have you hooked it directly to the modem via the cat5 cable? I wasn't sure if you meant you hooked it to the modem or router.
Mar 08, 2011 | Computers & Internet
My xbox is asking me to download an update to go online when it is nearly downloaded it says cant download and gives me a status code what do i have to do
You can download the update on a pc and burn it to disk to be applied to your console.
Instructions on how to do this can be found on the xbox update support page.
Jan 25, 2011 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
276 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
