Question about Fuller Brush Vacuums
How do i adjust hight on fuller vacume - Fuller Brush Vacuums
Need bags for fuller fb75t
We have bags for that vacuum here.
GoodVac.com
www.goodvac.com
1-800-775-6586
Apr 21, 2014 | Fuller Brush FB75T Upright Vacuum
Fuller Brush FB90 Bagged Upright Vacuum not starting
Try pushing the reset button located at the bottom on the back of the machine. If the reset button has tripped it usually indicates a clog or restriction somewhere caused the motor to overheat.
May 23, 2012 | Fuller Brush FB90 Bagged Upright Vacuum
The vacuum is not suctioning. Fuller FB 90T
First replace the belt if it's over 6 months old. Stretch belts lose elasticity. It may still turn the brush roll but when vacuuming the carpet it may be slipping and not turning fast enough. Make sure bags and filters are good.
Sep 07, 2011 | Fuller Brush FB90T Bagged Upright Vacuum
My fuller brush household canister vacuum doesn't have as much suction as usual. I've changed the bag and cleaned filter. Any other ideas?
. Test the suction without the pipes to confirm that the motor is sucking strongly, then check that there are no blockages in the pipes and fittings.
Jan 29, 2011 | Fuller Brush FBPTCAN Bagged Canister...
I have a cannister vacume, Fuller Brush red model # FB-DCC when I turn it on it will shut itself off in about 30 seconds this will happen several times then it will not turn on. I do not have the owners...
First, the word is "VACUUM." Second, it's obvoius that your motor is overheating. When's the last time you CLEANED THE FILTERS, per the operating instructions?
Nov 07, 2010 | Fuller Brush Vacuums
Hight adjustor does not work...
I think we got this figured out . . . . the height adjustment doesn't work when the vacuum is UPRIGHT, but when you disengage and lower the handle the plastic that is blocking the wheels from receding will rotate and then it can receive the plastic on the "top" of the wheel assembly. Try it and I think you will find that it works. I thought it was the wheels that were keeping the vacuum from working well, but that's not the case. Still don't know why it's gone to heck in 9 months.
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Fuller upright vacuum model FBPT-2
Be sure that you have the bag holder frame in place correctly.
The door will not close and latch without it.
Oct 02, 2008 | Fuller Brush FBPTCAN Bagged Canister...
Vacuums Logo
16 people viewed this question
Top Fuller Brush Vacuums Experts
Kevin Getz
Kevin Getz
ray gallant
Are you a Fuller Brush Vacuum Expert? Answer questions, earn points and help others
