Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Ice maker keeps overflowing with water
I woke up the other morning to a massive iceberg in my freezer. About every 5 minutes the water to the ice maker kicks on, spilling water out all over the freezer. What do I do?
  • Anonymous Feb 22, 2009
    My ice maker is overflowing water into my ice bin.  I know enough to shut the ice maker off.  My question is how can I fix this problem?
  • 700 Answers
Shut the water off behind the refrigerator.
Posted on Jan 19, 2009
Ice maker leaking into ice tray making icebergs
The icemaker could need seal replacement. Check with an appliance parts supplier.
Apr 14, 2014 | Maytag M1TXEGMYB 20.6 Cu. Ft. Top-Freezer...
The display panel shows OF and now it's not getting cold in either the freezer or frig.
he letters "OF" on the display of your RS267TDRS indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and a numeric reading returns to the display, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Unit turns on and starts to cool. Then runs for about 5 minutes and turns off. Unplug unit and plug back in and it repeats the problem. Will stay running.
It can be issue with temp sensor getting overheated or compressor getting overheated or issue with compressor relay or capacitor.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Marvel 61HK Commercial Beverage Dispenser
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Every 5-7 days the defrost water pan overflows. This morning I heard it filling up for 5 minutes or so.
That sould not happen, the condener fan should blow enough air over the pan to take of the waterl. Make sure your coils under your refrigertor are clean. You heard it filling? The only thing fills is the ice maker . I do not have much information. Is this a top mount, freezer on the top or a side by side
Sep 16, 2010 | Kenmore Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Whirlpool side by side (ED5VHGXMB10) Not ejecting Ice
take and power off the unit for 5 seconds and then see what happens,
Apr 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
383 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
