Question about Ariens 34 In. Zoom Series Riding Mower
John Deere snowblower model 828 drive won't engage
The drive pulleys will not make contact with the friction wheel using the hand grip. All belts are fine, chain is fine. The adjustment on the on the hand grip is fine. The manual does not provide any information.
2 Suggested Answers
  • 148 Answers
SOURCE: my snowblower on my john deere rider quit working
Check the idler pulley to make sure it didn't come off. Also make sure the spring is still connected to the idler pulley assembly.
Posted on Feb 06, 2011
John Deere 38" snowblower belt continues to come off even followingowing all diagrams.
check idler pulley and idler spring also make sure correct sized belt is being used
Dec 28, 2016 | John Deere Garden
I have a John Deere 820 tractor. I ran over a brick with mower blade engaged now I can't get blades to re-engage.
You probably have sheared the safety pin in your pulley drive. To change you have to take the pulley off. Try turning the pulley by hand If it turns free you did shear the pin.. Take spark plug wire off before so you do not hurt yourself. Safety first.
Apr 25, 2016 | John Deere Garden
Belt diagram john deere sabre 1338 GXABRF
the cheap john deeres are notorius for belt jump. Have to look at idler pulley while engaged in normal cutting height and see if it rides the upper edge of the idlers. I have had to bend up the idler arm so it runs a truer line into the pulley/idler so it doesnt creep over the edges.
Aug 30, 2014 | John Deere Garden
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
Sep 09, 2013 | Garden
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
John deere snowblower 826 will not shift out of drive.
Your drive control spring most likely broke. This will lead to the drive pulley and friction wheel continually being in contact. This will in turn lead to the snow thrower constantly being in drive. The spring should be stocked by the local dealer and is very easy to replace.
Jan 24, 2012 | Garden
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
John Deere Snowblower - wheel won't spin
yes 2 solutions. the sheer pins have got broken down on that auger that wont spin, they go through the middle bar. easy fix. about 2 dollar.
The other thing is. The drive belt located directly in the middle of the machine has a plastic cover over it has slipped off or is broken.
THis is a little more tricky as you split the machine taking off the collection cage usually to fix. I charge 89 dollars in my shop to do these.
Its not hard if you pay attention to where you need to take off the parts.
Feb 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Ariens Snowblower won't engage into drive
I had the same problem with my 5HP Dual stage (C950-520240) Canadian model and found that the arm connected to the traction cable (part #85449 "Shaft Traction Clutch") which forces the friction disk up to the rubber friction wheel had a cracked weld and had bent, preventing positive contact with the rubber friction wheel. The drive wheels would turn if you lifted the back of the machine off the ground, but would not work if under load. First I replaced the belt and rubber friction wheel, but no go. I had to basically disassemble the whole drive assembly to find the problem, very frustrating because you could not see the crack in the arm from head on. I had the cracked and bent arm straightened and welded, all is OK now. enb54.jpg
Dec 05, 2008 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
267 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
