Samsung washer wf350an not draining filter clean
  • 177 Answers
SOURCE: LInt filter
Find you owners manual, it should say how to clean the button trap on your pump
Unplug the machine FIRST!
Get some towels, you will have water coming out.
if the tub is full of water you will need to bale it out!
Remove the lower front panel, usually two screws,
look for the pump it will have hoses on it. now lay some towels around, expect water.
Unscrew the end of the pump, if it has a button trap or lint filter.
it will be on or near the pump refer to your owners manual
If you dont have an owners manual you may find it at Samsung.com?
Posted on May 03, 2008
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Same thing Happened to me I found that there was a small coin caught up in the filter..
Posted on Aug 31, 2008
jsrock516
  • 5911 Answers
SOURCE: washer will not drain. Need to know how to clean
The following link explains how to access and clean the drain pump reservoir on a Whirlpool Duet:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Jan 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Posted on Sep 18, 2010
  • 9 Answers
SOURCE: whirlpool washer runs all the time drain fliter is clean
check pcb, drain pump releated traic check it could be faulty
Posted on Aug 24, 2012
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Samsung washing machine nf Error code
Here is the best troubleshooting manual i've ever seen. It's PDF:
http://downloadcenter.samsung.com/content/UM/201106/20110628141933509/WF350AN-Tech-02834A-02.pdf
I found it here:
https://www.samsung.com/us/support/owners/product/WF350ANP/XAA
NOTE: If water is not entering tub, you almost certainly need to replace the water valve. If water is entering tub but won't fill your drain pump is suspect. Hope this helps.
Dec 30, 2012 | Samsung WF350ANP Front Load Tumble
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
Code "nd" on washer. just
If you got a "no drain" error yesterday, and cleaned the filter, did you check the drain lines? Also, make sure the waste pipe is correctly.
Dec 31, 2010 | Samsung Washing Machines
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Feb 13, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
