Question about Troy-Bilt Blower/Vac 31cc, 200 MPH, 405 CFM
Hello, My 31 cc troy built blower won't start. It's got spark. When I pulled the brand new plug it appeared to be completly dry. I sprayed ether in the cylinder and put the plug back in and it started for a brief moment. Not sure what's going on. Any help would be much appreciated. Thanks in advance.
  • 49 Answers
If the either burned, then you have a fuel problem. Make sure the fuel filter (in the tank) and the lines are all clear. If so, then you my need to rebiud the carburator.
Posted on Jan 30, 2009
Troy bilt sequall 2100 will not start. has new plug
Is the gas making it TO the new plug? Pull it over a dozen or so times on full choke and then pull the uh to see if its wet meaning the engine is getting fuel. Also make sure the safeties and off switches aren't preventing it from starting
Nov 18, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
My blower stops working after a few minutes and then shuts off
When it shuts off pull the plug wire and using a spark tester see if yo still have spark. If you have no spark you probably need a new coil. If you stil have spark put the plug wire back on and spray a little ether *(product usually called "instant start") and see if it starts momentarily. If it does your carb is in need of a cleaning. Most have tiny screens that plug up over time. Replacing this screen is recommended. Cleaning almost never works!
Oct 01, 2013 | Garden
Tb320bv blower, I can set the choke and start it but it will not run. As soon as the choke pops off during acceleration the blower dies.
This would indicate that you need a new diaphram in the carby not very expensive any mower shop will do for about $30
Jun 25, 2010 | Troy-Bilt Mtd Southwest Tb320bv...
How do you adjust the carburetor
There is probably no adjustment. They don't want ordinary guys work'n on their own stuff any more...Lol. If you are having carb. problems try this:
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 31, 2009 | Troy-Bilt Mtd Southwest Tb320bv...
Pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Sep 06, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Troy-Bilt Blower/Vac 31cc, 200 MPH, 405 CFM Logo
435 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
